Please reply to the list so other people can also see the problem and hopefully the solution.
I just remembered that you can also just dump to one file, using just
dump compress.dump
to generate the data. Then you can just rerun that dump file which contains all the snapshots. You can also concatenate them from the command line with
cat compress.dump.* > compress.dump
and use that.
