Dear LAMMPS users,
I would like to use the label keyword in the read_dump command, but
receive the error:
ERROR: Illegal read_dump command (../read_dump.cpp:668)
Please note that my problem has NOT been solved in
http://lammps.sandia.gov/threads/msg40572.html .
As an example, extend the Cu solid benchmark input file
lammps-8Aug14/bench/in.eam:
I’ll take a look - thanks for the detailed explanation.
yes, that was a bug - the logic for the label matching was messed up.
will post a patch later this AM.
Thanks for pinpointing the problem,
Thank you Steve for fixing it - keep up the good work with LAMMPS!
This is also helpful since I may have to distribute a LAMMPS installation
on our servers and do not want to resort to any customized "unofficial"
version just to make such an input file work.
Jan
