lammps version – LAMMPS (22 Jul 2025 - Update 1)
I am was trying to read unwrapped coordinates from a native dump file using the following command
read_dump dump.lammpstrj 1 xu yu zu box yes
ITEM: ATOMS id xu yu zu
1 120.429 0.173 7.989
I do have atom ids in my dump file (see above)
but I get an error Read_dump must use at least either ‘id’ or ‘type’ field
I used id field still the same error. However when I use x y z I get no error although that field is not in the dump file
Not sure if I am missing something here. I want to replace the current simulation coordinates as read from read_data with unwrapped coordinates using the read_dump command
any help is appreciated
Arun
