Yes, it's been checked with a memory leak check program Valgrind that
reax/c currently has no memory leaks. However you can get error messages
for bad setups.
Ray
for bad setups.
Ray
i guess at this point this boils down to:
a) produce an example input that you think should run well, but doesn't
or
b) double check your system for any components that may be unphysical
it is difficult to debug something that doesn't show up
in the known inputs.
cheers,
Hello all and thanks for responses. Then let me check once more and I’ll post soon if anything was wrong with my setup, otherwise I’ll provide an input script. Thanks again.
