Stephane,
Your box shrunk quite a bit in the last stage so the neighbor list might need more frequent reconstructions. Could you try:
1) increase the safezone and mincap values, and
2) increase neighbor list construction frequency (via neigh_modify command).
Stephane,
command).
...and perhaps run the initial equilibration as a separate input, writing
out a restart (or data) file at the end, and continue with the same
settings after reading back the restart (or data) file in a second input.
that avoids any issues due to overflowing those heuristic array dimensions.
p.s.: ray, couldn't we have some simple check, that is run infrequently and
would print a warning, when any of those heuristically pre-allocated arrays
are close to overflowing? there seems to be a recurring theme here, and
this kind of warning would be extremely helpful to many users but also
developers. there is a similar thing for neighbor lists...
I suspect that this problem is caused by the Nose-Hoover barostat, which is prone to numerical instabilities, especially for small systems.
fix fxnpt all npt temp 283 283 10 iso 1 1 100
100 fs is a rather fast time constant and not necessary given how slowly evolving the simulation is. I suspect if you increase that to 1 ps or 10 ps, your problems will go away. You could also try switching to a more stable but less rigorous form of barostatting, such as using the drag keyword, or using the Berendsen barostat.
Aidan
p.s.: ray, couldn’t we have some simple check, that is run infrequently and would print a warning, when any of those heuristically pre-allocated arrays are close to overflowing? there seems to be a recurring theme here, and this kind of warning would be extremely helpful to many users but also developers. there is a similar thing for neighbor lists…
FYI, we are working on a new version of ReaxFF that doesn’t rely on the heuristics and should be more memory robust.
Stan
