Hi
I compiled lammps with reax option, when I run my code I get the errors below, the manual say this : reax_defs.h contains dimensions of statically-allocated arrays created by the ReaxFF library. The size of these arrays must be set small enough to avoid exceeding the available machine memory, and large enough to fit the actual data generated by ReaxFF. If you change the values in reax_defs.h, you must first rebuild the library and then rebuild LAMMPS. Is this the reason for the errors?
Setting up run …
[s6-1:27667] *** Process received signal ***
[s6-1:27667] Signal: Segmentation fault (11)
[s6-1:27667] Signal code: Address not mapped (1)
[s6-1:27667] Failing at address: (nil)
[s15-2:00706] *** Process received signal ***
[s15-2:00706] Signal: Segmentation fault (11)
[s15-2:00706] Signal code: Address not mapped (1)
[s15-2:00706] Failing at address: (nil)
[s5-3:10892] *** Process received signal ***
[s5-3:10892] Signal: Segmentation fault (11)
[s5-3:10892] Signal code: Address not mapped (1)
[s5-3:10892] Failing at address: (nil)
[s6-1:27668] *** Process received signal ***
[s6-1:27668] Signal: Segmentation fault (11)
[s6-1:27668] Signal code: Address not mapped (1)
[s6-1:27668] Failing at address: (nil)
[s5-10:01445] *** Process received signal ***
Thank you
