ReaxFF Charge Equilibriation for Both Metals & Organics
I’m relatively new to lammps so let me know if there are things I should look into/read relating to this.
I am trying to simulate an organic molecule breaking up on impact with a metal surface. I was provided a parameters file that has all the atoms I need for the impactor (C H N B F) and Ti, which is close enough to what I need for the target.
Using the pair_style reax/c I was able to thermalize the impactor and target plate to the desired temperatures, but when I put them both into a simulation where they can come into contact at the first frame of constant 20% of the atoms disappear and “nan” values are generated for positions/velocities.
Is there something obviously I am missing in the input below?
Here is my Lammps input file (I am trying to upload the .dat files, I can add them as text if needed):
clear
units       real
atom_style  full
boundary    m m m
# EMI-BF Impactor: Atom Types 1-5
read_data EMIBF4_eq300_rotated.dat group EMI extra/atom/types 1
displace_atoms EMI move -50 3.6 -2.6
# Ti Wall Target: Atom Types 6
read_data ti_wall.dat add append group WALL
displace_atoms WALL move 0 -15 15
pair_style	    reax/c NULL #checkqeq no
pair_coeff	* * ffield_IL.txt N C H B F Ti
fix  1 all qeq/reax 1 0.0 10.0 1e-4 reax/c
fix EFIX all nve
thermo_style custom step etotal
thermo 100
timestep 0.5
dump 1 all custom 100 pos.xyz id type x y z q
dump_modify 1 units yes
dump 2 all custom 10000 final.xyz id type x y z q
dump_modify 2 units yes
run 10000
unfix EFIX
undump 1
undump 2
Here is the Force Field File pt1
Reactive MD-force field: Bi(new)+BMIM_NO2 08/15/2016
 39       ! Number of general parameters
   50.0000 !Overcoordination parameter
    9.5469 !Overcoordination parameter
    1.6725 !Valency angle conjugation parameter
    1.7224 !Triple bond stabilisation parameter
    6.8702 !Triple bond stabilisation parameter
   60.4850 !C2-correction
    1.0588 !Undercoordination parameter
    4.6000 !Triple bond stabilisation parameter
   12.1176 !Undercoordination parameter
   13.3056 !Undercoordination parameter
  -70.5044 !Triple bond stabilization energy
    0.0000 !Lower Taper-radius
   10.0000 !Upper Taper-radius
    2.8793 !Not used
   33.8667 !Valency undercoordination
    6.0891 !Valency angle/lone pair parameter
    1.0563 !Valency angle
    2.0384 !Valency angle parameter
    6.1431 !Not used
    6.9290 !Double bond/angle parameter
    0.3989 !Double bond/angle parameter: overcoord
    3.9954 !Double bond/angle parameter: overcoord
   -2.4837 !Not used
    5.7796 !Torsion/BO parameter
   10.0000 !Torsion overcoordination
    1.9487 !Torsion overcoordination
   -1.2327 !Conjugation 0 (not used)
    2.1645 !Conjugation
    1.5591 !vdWaals shielding
    0.1000 !Cutoff for bond order (*100)
    1.7602 !Valency angle conjugation parameter
    0.6991 !Overcoordination parameter
    1.8512 !Valency/lone pair parameter
    0.5000 !Not used
   20.0000 !Not used
    5.0000 !Molecular energy (not used)
    0.0000 !Molecular energy (not used)
    0.7903 !Valency angle conjugation parameter
 14   ! Nr of atoms; cov.r; valency;a.m;Rvdw;Evdw;gammaEEM;cov.r2;#
            alfa;gammavdW;valency;Eunder;Eover;chiEEM;etaEEM;n.u.
            cov r3;Elp;Heat inc.;n.u.;n.u.;n.u.;n.u.
            ov/un;val1;n.u.;val3,vval4
 C    1.3663   4.0000  12.0000   2.0451   0.1164   0.7788   1.1706   4.0000
      9.1188   1.9055   4.0000  30.0000  79.5548   4.7780   7.0464   0.0000
      1.1168   0.0000 181.0000  14.2277  24.4367   6.7313   0.8563   0.0000
     -7.0353   4.8952   1.0564   4.0000   2.9663   0.0000   0.0000   0.0000
 H    0.8924   1.0000   1.0080   1.6791   0.0709   0.7390  -0.1000   1.0000
      8.3519  39.1732   1.0000   0.0000 121.1250   3.5442   9.3848   1.0000
     -0.1000   0.0000  61.6606   2.8222   2.1441   0.0003   1.0698   0.0000
    -18.1423   5.3143   1.0338   1.0000   2.8793   0.0000   0.0000   0.0000
 O    1.2450   2.0000  15.9990   2.3396   0.1000   1.1000   1.0548   6.0000
      9.3187  12.5083   4.0000  37.5000 116.0768   8.5000   8.4783   2.0000
      0.9049   0.1000  59.0626   3.4340   0.7722   0.0021   0.9745   0.0000
     -3.5352   3.2703   1.0493   4.0000   2.9225   0.0000   0.0000   0.0000
 N    1.2333   3.0000  14.0000   1.9324   0.1376   0.7735   1.1748   5.0000
     10.0667   7.8431   4.0000  32.2482 100.0000   7.5731   6.3952   2.0000
      1.0433  27.4419 119.9837   1.9649   4.3011   3.4430   0.9745   0.0000
     -4.3875   2.6192   1.0183   4.0000   2.8793   0.0000   0.0000   0.0000
 S    1.9405   2.0000  32.0600   2.0677   0.2099   1.0336   1.5479   6.0000
      9.9575   4.9055   4.0000  52.9998 112.1416   5.7824   8.2545   2.0000
      1.4601   9.7177  71.1843   5.7487  23.2859  12.7147   0.9745   0.0000
    -11.0000   2.7466   1.0338   6.2998   2.8793   0.0000   0.0000   0.0000
 Mg   1.8315   2.0000  24.3050   2.2464   0.1806   0.5020   1.0000   2.0000
     10.9186  27.1205   3.0000  38.0000   0.0000   0.9499   5.6130   0.0000
     -1.3000   0.0000 127.9160  49.9248   0.3370   0.0000   0.0000   0.0000
     -1.0823   2.3663   1.0564   6.0000   2.9663   0.0000   0.0000   0.0000
 P    1.5994   3.0000  30.9738   1.7000   0.1743   1.0000   1.3000   5.0000
      9.1909  14.9482   5.0000   0.0000   0.0000   1.6676   7.0946   0.0000
     -1.0000  25.0000   1.5000   0.2187  21.4305  15.1425   0.0000   0.0000
     -3.9294   3.4831   1.0338   5.0000   2.8793   0.0000   0.0000   0.0000
 Na   1.8000   1.0000  22.9898   2.8270   0.1872   0.4000  -1.0000   1.0000
     10.0000   2.5000   1.0000   0.0000   0.0000  -0.9871   6.7728   0.0000
     -1.0000   0.0000  23.0445 100.0000   1.0000   0.0000   0.8563   0.0000
     -2.5000   3.9900   1.0338   8.0000   2.5791   0.0000   0.0000   0.0000
 Ti   2.0254   4.0000  47.8800   2.2105   0.1574   0.6311   0.1000   4.0000
     12.7041  16.6482   4.0000   0.1000   0.0000  -1.3647   6.8406   0.0000
     -1.0000   0.0000 143.1770  27.6505  -0.0753   0.0064   0.8563   0.0000
    -15.0000   3.8359   1.0338  12.0000   2.2632   0.0000   0.0000   0.0000
 Cl   1.7140   1.0000  35.4500   1.9139   0.2000   0.3500  -1.0000   7.0000
     11.5345  10.1330   1.0000   0.0000   0.0000   9.9704   6.1703   0.0000
     -1.0000   1.2769 143.1770   6.2293   5.2294   0.1542   0.8563   0.0000
    -10.2080   2.9867   1.0338   6.2998   2.5791   0.0000   0.0000   0.0000
 F    1.2100   1.0000  18.9984   1.8601   0.1200   0.8000  -0.1000   7.0000
     11.5000   7.5000   4.0000   9.2533   0.2000   9.0000   7.0000   0.0000
     -1.0000  35.0000   1.5000   6.9821   4.1799   1.0561   0.0000   0.0000
     -7.3000   2.6656   1.0493   4.0000   2.9225   0.0000   0.0000   0.0000
 Bi   2.9805   3.0000 208.9804   2.6414   0.4500   0.7763   0.0535   5.0000
     10.0023   1.7008   3.0000   0.0000   0.0000  -0.2383   7.9580   0.0000
     -1.0000   0.0000  92.5070   3.2928   0.5000   0.1542   0.8563   0.0000
     -4.4244   1.6039   1.0338   6.2998   2.5791   0.0000   0.0000   0.0000
 B    1.1936   3.0000  10.8110   1.8368   0.0708   0.7695  -1.0000   3.0000
      9.0332   3.6413   3.0000  38.0000   0.0000   2.3652   8.5128   0.0000
     -1.3000   0.0000 220.0000   5.4000  24.0000  12.0000   0.0000   0.0000
    -10.8644   2.4601   1.0564   6.2998   2.9663   0.0000   0.0000   0.0000
 X   -0.1000   2.0000   1.0080   2.0000   0.0000   1.0000  -0.1000   6.0000
     10.0000   2.5000   4.0000   0.0000   0.0000   8.5000   1.5000   0.0000
     -0.1000   0.0000  -2.3700   8.7410  13.3640   0.6690   0.9745   0.0000
    -11.0000   2.7466   1.0338   4.0000   2.8793   0.0000   0.0000   0.0000
 73     ! Nr of bonds; Edis1;LPpen;n.u.;pbe1;pbo5;13corr;pbo6
                         pbe2;pbo3;pbo4;Etrip;pbo1;pbo2;ovcorr
  1  1  80.7780 115.6384  43.3946   0.4114  -0.1976   1.0000  34.9698   0.5923
         6.1892  -0.1585   7.9720   1.0000  -0.0433   7.7423   1.0000   0.0000
  1  2 181.3418   0.0000   0.0000  -0.4710   0.0000   1.0000   6.0000   0.5243
        12.0704   1.0000   0.0000   1.0000  -0.0652   6.5639   0.0000   0.0000
  2  2 165.6186   0.0000   0.0000  -0.4194   0.0000   1.0000   6.0000   0.6197
         6.3245   1.0000   0.0000   1.0000  -0.0879   6.0634   0.0000   0.0000
  1  3 163.4842  83.9973  54.4316  -0.5213  -0.3123   1.0000  10.2503   1.0000
         0.3303  -0.3757   7.0000   1.0000  -0.1331   4.6020   0.0000   0.0000
  3  3 142.2858 145.0000  50.8293   0.2506  -0.1000   1.0000  29.7503   0.6051
         0.3451  -0.1055   9.0000   1.0000  -0.1225   5.5000   1.0000   0.0000
  1  4 177.5574 119.0316  79.9745   0.0450  -0.1428   1.0000  27.0617   0.1813
         0.1381  -0.3242   7.1101   1.0000  -0.1310   5.1589   1.0000   0.0000
  3  4 122.2076 203.9405  40.0000  -1.6190  -0.3056   1.0000  35.0000   0.0250
         0.6251  -0.2843   8.3801   1.0000  -0.0916   5.5686   1.0000   0.0000
  4  4 101.5574  81.5346 152.3498   0.3608  -0.1000   1.0000  12.4206   0.5564
         0.1248  -0.1441  11.9132   1.0000  -0.0907   5.6734   1.0000   0.0000
  2  3 169.9254  69.0261   0.0000  -0.5725   0.0000   1.0000   6.0000   0.5626
         1.1150   1.0000   0.0000   0.0000  -0.0920   4.2790   0.0000   0.0000
  2  4 204.6448   0.0000   0.0000  -0.4989   0.0000   1.0000   6.0000   0.1621
         7.3710   1.0000   0.0000   1.0000  -0.0437   6.0357   0.0000   0.0000
  1  5 128.7959  56.4134  39.0716   0.0688  -0.4463   1.0000  31.1766   0.4530
         0.1955  -0.3587   6.2148   1.0000  -0.0770   6.6386   1.0000   0.0000
  2  5 136.1049   0.0000   0.0000  -0.4669   0.0000   1.0000   6.0000   0.3803
        10.5730   1.0000   0.0000   1.0000  -0.1000   7.0000   1.0000   0.0000
  3  5 135.6998 220.0000  40.0000   0.5848  -0.2406   1.0000  22.1005   0.2335
         0.7069  -0.2681   8.3465   1.0000  -0.0922   5.4651   1.0000   0.0000
  4  5   0.0000   0.0000   0.0000   0.5000  -0.2000   1.0000  40.0000   0.3000
         0.4000  -0.2500   9.0000   1.0000  -0.1000   6.0000   1.0000   0.0000
  5  5   0.0000   0.0000   0.0000   0.2500  -0.5000   1.0000  20.0000   1.0000
         0.2500  -0.2500  10.0000   1.0000  -0.1000   8.0000   1.0000   0.0000
  2  6  58.6896   0.0000   0.0000  -0.0203  -0.1418   1.0000  13.1260   0.0230
         8.2136  -0.1310   0.0000   1.0000  -0.2692   6.4254   0.0000  24.4461
  3  6  87.0227   0.0000  43.3991   0.0030  -0.3000   1.0000  36.0000   0.0250
         0.0087  -0.2500  12.0000   1.0000  -0.0439   6.6073   1.0000  24.4461
  6  6  32.3808   0.0000   0.0000  -0.0076  -0.2000   0.0000  16.0000   0.2641
         4.8726  -0.2000  10.0000   1.0000  -0.0729   4.6319   0.0000   0.0000
  1  7 110.0000  92.0000   0.0000   0.2171  -0.1418   1.0000  13.1260   0.6000
         0.3601  -0.1310  10.7257   1.0000  -0.0869   5.3302   1.0000   0.0000
  2  7   0.1466   0.0000   0.0000   0.2250  -0.1418   1.0000  13.1260   0.6000
         0.3912  -0.1310   0.0000   1.0000  -0.1029   9.3302   0.0000   0.0000
  3  7 201.0058 194.1410   0.0000   1.0000  -0.5000   1.0000  25.0000   0.4873
         0.4358  -0.1571  15.8745   1.0000  -0.2431   6.3823   1.0000   0.0000
  4  7 130.0000   0.0000   0.0000   0.2171  -0.1418   1.0000  13.1260   0.6000
  6  7   0.1000   0.0000   0.0000   0.2500  -0.5000   1.0000  35.0000   0.6000
         0.5000  -0.5000  20.0000   1.0000  -0.2000  10.0000   1.0000   0.0000
  7  7   0.0000   0.0000   0.0000   0.2171  -0.5000   1.0000  35.0000   0.6000
  1  8   0.0000   0.0000   0.0000  -1.0000  -0.3000   1.0000  36.0000   0.7000
        10.1151  -0.3500  25.0000   1.0000  -0.1053   8.2003   1.0000   0.0000
  2  8   0.0000   0.0000   0.0000  -1.0000  -0.3000   1.0000  36.0000   0.7000
  3  8  45.8933   0.0000   0.0000  -0.1511  -0.3000   1.0000  36.0000   0.3105
         5.8448  -0.3500  25.0000   1.0000  -0.0659   7.9140   1.0000   0.0000
  4  8   0.0000   0.0000   0.0000  -1.0000  -0.3000   1.0000  36.0000   0.7000
  5  8   0.0000   0.0000   0.0000  -1.0000  -0.3000   1.0000  36.0000   0.7000
  6  8   0.0000   0.0000   0.0000   0.2500  -0.5000   1.0000  35.0000   0.6000
  7  8   0.0000   0.0000   0.0000   0.2500  -0.5000   1.0000  35.0000   0.6000
  8  8  64.4508   0.0000   0.0000  -0.3738   0.3000   0.0000  25.0000   0.2158
         0.9915  -0.4000  12.0000   1.0000  -0.0515   5.0000   0.0000   0.0000
  4  6  50.0000  10.0901   0.0000  -1.0000  -0.3000   1.0000  36.0000   0.7058
         0.8567  -0.3487  17.4990   1.0000  -0.0794   8.2232   1.0000   0.0000
  1  9   0.0000   0.0000   0.0000  -0.2872  -0.3000   1.0000  36.0000   0.0082
         1.7973  -0.2500  20.0000   1.0000  -0.2578   6.5219   1.0000   0.0000
  2  9   0.0000   0.0000   0.0000  -0.2872  -0.3000   1.0000  36.0000   0.0082
  3  9 130.5629  37.6984   0.0000   0.9228  -0.3000   0.0000  36.0000   0.0850
         0.1150  -0.2818  16.1571   1.0000  -0.1343   6.8264   0.0000   0.0000
  4  9   0.0000   0.0000   0.0000  -0.2872  -0.3000   1.0000  36.0000   0.0082
  5  9   0.0000   0.0000   0.0000  -0.2872  -0.3000   1.0000  36.0000   0.0082
  6  9   0.0000   0.0000   0.0000  -0.2872  -0.3000   1.0000  36.0000   0.0082
  7  9   0.0000   0.0000   0.0000  -0.2872  -0.3000   1.0000  36.0000   0.0082
  8  9   0.1000   0.0000   0.0000   0.2500  -0.5000   1.0000  35.0000   0.6000
  9  9  80.1930   0.0000   0.0000  -0.8469  -0.2000   0.0000  16.0000   0.2022
         0.7528  -0.1924  14.9725   1.0000  -0.0885   5.0000   0.0000   0.0000
  1 10   0.0000   0.0000   0.0000   0.5000  -0.2000   0.0000  16.0000   0.5000
         1.0001  -0.2000  15.0000   1.0000  -0.1000  10.0000   0.0000   0.0000
  2 10  98.9788   0.0000   0.0000  -0.0572  -0.2000   0.0000  16.0000   1.1523
         2.2822  -0.2000  15.0000   1.0000  -0.1093   5.1686   0.0000   0.0000
  3 10   0.0000   0.0000   0.0000   0.5000  -0.2000   0.0000  16.0000   0.5000
  4 10   0.0000   0.0000   0.0000   0.5000  -0.2000   0.0000  16.0000   0.5000
  5 10   0.0000   0.0000   0.0000   0.5000  -0.2000   0.0000  16.0000   0.5000
  6 10   0.0000   0.0000   0.0000   0.5000  -0.2000   0.0000  16.0000   0.5000
  7 10   0.0000   0.0000   0.0000   0.5000  -0.2000   0.0000  16.0000   0.5000
  8 10   0.0000   0.0000   0.0000   0.5000  -0.2000   0.0000  16.0000   0.5000
  9 10 133.8732   0.0000   0.0000  -0.0830  -0.2000   0.0000  16.0000   0.5483
         0.1065  -0.2000  15.0000   1.0000  -0.0553   8.5063   0.0000   0.0000
 10 10   0.2500   0.0000   0.0000   0.1803  -0.2000   0.0000  16.0000   0.3356
         0.9228  -0.2000  15.0000   1.0000  -0.1178   5.6715   0.0000   0.0000
  1 11 237.8781   0.0000   0.0000  -0.7438  -0.5000   1.0000  35.0000   1.0460
         3.6661  -0.2500  15.0000   1.0000  -0.0800   5.4719   1.0000   0.0000
  2 11   0.0000   0.0000   0.0000  -0.4643   0.0000   1.0000   6.0000   0.6151
        12.3710   1.0000   0.0000   1.0000  -0.1008   8.5980   0.0000   0.0000
  3 11   0.0000   0.0000   0.0000   0.2500  -0.5000   1.0000  45.0000   0.6000
         0.4000  -0.2500  15.0000   1.0000  -0.1000  10.0000   1.0000   0.0000
  4 11   0.0000   0.0000   0.0000  -0.4643   0.0000   1.0000   6.0000   0.6151
        12.3710   1.0000   0.0000   1.0000  -0.0098   8.5980   0.0000   0.0000
  5 11   0.0000   0.0000   0.0000  -0.4643   0.0000   1.0000   6.0000   0.6151
  7 11 157.5115   0.0000   0.0000   0.1052  -0.5000   1.0000  50.0000   0.1000
         0.4611  -0.5000  15.0000   1.0000  -0.0834   5.3650   1.0000   0.0000
 11 11 250.0765   0.0000   0.0000   0.2298  -0.3500   1.0000  25.0000   0.8427
         0.1167  -0.2500  15.0000   1.0000  -0.1506   7.3516   1.0000   0.0000
  1 12 104.3083   0.0000   0.0000   0.0111  -0.3000   1.0000  36.0000  -0.5453
         7.3704  -0.2975   8.6248   1.0000  -0.1188   4.5432   0.0000   0.0000
  2 12   0.0000   0.0000   0.0000  -0.3096  -0.3000   1.0000  36.0000  -0.0153
         0.7515  -0.1970   9.1203   1.0000  -0.1309   8.0000   0.0000   0.0000
  3 12 161.0105 122.5589   0.0000  -0.5978  -0.3000   1.0000  36.0000   0.9088
         1.4840  -0.8620   6.0878   1.0000  -0.1762   5.2942   0.0000   0.0000
  7 12   0.0000   0.0000   0.0000   0.2500  -0.5000   1.0000  45.0000   0.7500
         0.5000  -0.4000  20.0000   1.0000  -0.2000   9.0000   0.0000   0.0000
 12 12  53.5577   0.0000   0.0000  -0.9983  -0.2000   0.0000  16.0000   0.1008
         1.9017  -0.2000  15.0000   1.0000  -0.0638  10.7829   0.0000   0.0000
  4 12  54.8424   0.0000   0.0000   0.3637  -0.3000   1.0000  36.0000   0.4433
        11.9215  -0.3436   9.3892   1.0000  -0.0578   6.5598   1.0000   0.0000
 11 12 130.0438   0.0000   0.0000  -0.9901  -0.3000   1.0000  36.0000   0.5179
        11.9873  -0.1436   9.4516   1.0000  -0.0703   6.7592   0.0000   0.0000
  1 13   0.0000   0.0000   0.0000   0.2500  -0.5000   1.0000  45.0000   0.7500
         0.5000  -0.4000  20.0000   1.0000  -0.2000   9.0000   1.0000   0.0000
  2 13   0.0000   0.0000   0.0000   0.2500  -0.5000   1.0000  45.0000   0.7500
  3 13   0.0000   0.0000   0.0000   0.2500  -0.5000   1.0000  45.0000   0.7500
  4 13   0.0000   0.0000   0.0000   0.2500  -0.5000   1.0000  45.0000   0.7500
 11 13 138.8437   0.0000   0.0000   0.1970  -0.5000   1.0000  50.0000   0.4965
         0.3303  -0.2500  40.0000   1.0000  -0.1201   5.3131   1.0000   0.0000
 12 13   0.0000   0.0000   0.0000   0.2500  -0.5000   1.0000  45.0000   0.7500
 13 13   0.0000   0.0000   0.0000   0.2500  -0.5000   1.0000  45.0000   0.7500
Force Field File Pt2:
30    ! Nr of off-diagonal terms; Ediss;Ro;gamma;rsigma;rpi;rpi2
  1  2   0.1202   1.3883   9.8843   1.1406  -1.0000  -1.0000
  2  3   0.0283   1.2853  10.9173   0.9259  -1.0000  -1.0000
  2  4   0.0733   1.6660   9.9551   0.9258  -1.0000  -1.0000
  1  3   0.1347   1.8343   9.7934   1.3139   1.1498   1.1039
  1  4   0.1305   2.0255   9.8145   1.3291   1.1867   1.1496
  3  4   0.1631   1.8072   9.7444   1.4995   1.1478   0.9392
  1  5   0.1408   1.8161   9.9393   1.7986   1.3021   1.4031
  2  5   0.0895   1.6239  10.0104   1.4640  -1.0000  -1.0000
  3  5   0.1962   1.7872  10.2319   1.4622   1.4025  -1.0000
  4  5   0.1505   1.9000  10.5104   1.8000   1.4000  -1.0000
  2  6   0.0100   1.6000  13.2979   1.8670  -1.0000  -1.0000
  3  6   0.0809   1.7000  11.4606   1.5177  -1.0000  -1.0000
  3  7   0.0534   1.7520  10.4281   1.8000   1.4498  -1.0000
  6  7   0.1801   1.8566   9.8498   0.1000  -1.0000  -1.0000
  3  8   0.0825   1.5904  11.3396   1.5905  -1.0000  -1.0000
  2  9   0.1750   1.7939  13.5000   0.0100  -1.0000  -1.0000
  3  9   0.1200   1.8000  10.5000   1.6526   1.4718  -1.0000
 10  9   0.1368   2.2000  12.5000   1.8549   1.4718  -1.0000
  1  9   0.2035   1.7007  11.4530   0.0100  -1.0000  -1.0000
  2 10   0.0376   1.6671   9.6285   1.2123  -1.0000  -1.0000
  3 10   0.1945   2.2766  11.2353  -1.0000  -1.0000  -1.0000
  1 11   0.1090   1.6393  11.2302   1.3176  -1.0000  -1.0000
  2 11   0.0890   1.7611  10.8079   0.5976  -1.0000  -1.0000
  7 11   0.1098   1.7498   9.7288   1.3711  -1.0000  -1.0000
  1 12   0.2920   1.6571  13.3027   1.6877   1.0134  -1.0000
  2 12   0.0500   1.7000  11.0000   1.6862   1.5080  -1.0000
  3 12   0.2562   2.0077  11.4254   1.9014   1.7980  -1.0000
  4 12   0.0508   1.9522  13.1873   1.7592  -1.0000  -1.0000
 11 12   0.1429   1.7303  13.5000   2.4035   1.2000  -1.0000
 11 13   0.1000   1.7500   9.5000   1.2500  -1.0000  -1.0000
115   ! Nr of angles;at1;at2;at3;Thetao,o;ka;kb;pv1;pv2
  1  1  1  71.4607  44.3163   0.7285   0.0000   1.6866  20.4954   1.9776
  1  1  2  62.9686  12.8941   4.6125   0.0000   0.0389   0.0000   1.0010
  2  1  2  74.1639  21.5725   0.9280   0.0000   3.0000   0.0000   1.0608
  1  2  2   0.0000   0.0000   6.0000   0.0000   0.0000   0.0000   1.0400
  1  2  1   0.0000   7.5000   5.0000   0.0000   0.0000   0.0000   1.0400
  2  2  2   0.0000  27.9213   5.8635   0.0000   0.0000   0.0000   1.0400
  1  1  3  15.7798   9.0805   4.0304   0.0000   1.8785  70.0000   1.1737
  3  1  3  74.7266  45.0000   1.8020 -16.7178   2.6091   0.1000   2.3556
  1  1  4  66.2891  15.5198   7.2492   0.0000   0.6131  50.0000   1.8827
  3  1  4  73.9544  12.4661   7.0000   0.0000   1.1046   0.0000   1.1880
  4  1  4  89.9882  22.3796   6.9176   0.0000   4.7734   0.0000   2.7478
  2  1  3  65.0000  13.4505   1.8249   0.0000   1.5646   0.0000   1.2173
  2  1  4  61.0053  29.1133   2.1610   0.0000   0.6361   0.0000   1.0400
  1  2  4   0.0000   0.0019   6.3000   0.0000   0.0000   0.0000   1.0400
  1  3  1  76.7840  44.2266   0.9343   0.0000   1.3483   0.0000   1.8301
  1  3  3  63.9120  17.1680   0.8751   0.0000   0.0693  50.9415   3.0000
  1  3  4  69.7249  43.3620   1.2363   0.0000   1.5227   0.0000   1.2901
  3  3  3  80.7324  30.4554   0.9953   0.0000   1.6310  50.0000   1.0783
  3  3  4  84.3637  31.4554   0.9953   0.0000   3.0000   0.0000   1.0783
  4  3  4  89.7071  31.4554   0.9953   0.0000   3.0000   0.0000   1.1519
  1  3  2  79.6413  28.6488   0.3789   0.0000   1.6776   0.0000   1.0010
  2  3  3  79.5453  50.0000   2.1630   0.0000   3.0000   0.0000   1.2391
  2  3  4  78.5222  45.0000   1.0981   0.0000   0.6726   0.0000   1.2023
  2  3  2  85.7876   9.3298   2.0747   0.0000   2.8632   0.0000   1.6905
  1  4  1  80.7237  22.4376   0.9037   0.0000   6.0136   0.0000   1.0400
  1  4  3  84.0357  13.8415   7.5000   0.0000   6.7219   0.0000   1.1161
  1  4  4  50.1493  26.7660   4.2832   0.0000   6.5556   0.0000   1.2474
  3  4  3  78.9434  42.1394   5.9735 -49.7500   6.8560   0.0000   1.1773
  3  4  4  74.8600  43.7354   1.1572  -0.9193   6.5556   0.0000   1.1543
  4  4  4  75.0538  14.8267   5.2794   0.0000   6.5556   0.0000   1.1543
  1  4  2  68.5310  27.1114   1.6183   0.0000   0.4390   0.0000   1.1309
  2  4  3  81.3686  40.0712   2.2396   0.0000   0.4216   0.0000   1.3430
  2  4  4  83.0104  43.4766   1.5328   0.0000   0.4216   0.0000   1.3430
  2  4  2  79.0002  17.7860   3.7968   0.0000   0.0222   0.0000   2.0317
  1  2  3   0.0000  45.0000   3.0000   0.0000   1.0000   0.0000   1.0400
  1  2  4   0.0000   0.0019   6.0000   0.0000   0.0000   0.0000   1.0400
  1  2  5   0.0000   0.0019   6.0000   0.0000   0.0000   0.0000   1.0400
  3  2  3   0.0000  15.0000   3.0000   0.0000   0.0000   0.0000   2.9453
  3  2  4   0.0000   0.0019   6.0000   0.0000   0.0000   0.0000   1.0400
  4  2  4   0.0000   0.0019   6.0000   0.0000   0.0000   0.0000   1.0400
  2  2  3   0.0000   5.8938   3.0000   0.0000   0.0000   0.0000   1.0629
  2  2  4   0.0000   0.0019   6.0000   0.0000   0.0000   0.0000   1.0400
  1  1  5  74.4180  33.4273   1.7018   0.1463   0.5000   0.0000   1.6178
  1  5  1  79.7037  28.2036   1.7073   0.1463   0.5000   0.0000   1.6453
  2  1  5  63.3289  29.4225   2.1326   0.0000   0.5000   0.0000   3.0000
  1  5  2  85.9449  38.3109   1.2492   0.0000   0.5000   0.0000   1.1000
  1  5  5  85.6645  40.0000   2.9274   0.1463   0.5000   0.0000   1.3830
  2  5  2  83.8555   5.1317   0.4377   0.0000   0.5000   0.0000   3.0000
  2  5  5  97.0064  32.1121   2.0242   0.0000   0.5000   0.0000   2.8568
  3  5  3  81.0926  30.2268   6.4132  -5.4471   2.5968   0.0000   3.0000
  1  5  3  70.0000  35.0000   3.4223   0.0000   1.3550   0.0000   1.2002
  1  3  5  57.3353  41.0012   1.0609   0.0000   1.3000   0.0000   3.0000
  3  3  5  83.9753  31.0715   3.5590   0.0000   0.8161   0.0000   1.1776
  2  3  5  89.8843  17.5000   3.3660   0.0000   2.0000   0.0000   2.0734
  2  6  2   0.0000  49.8261   0.2093   0.0000   2.0870   0.0000   2.2895
  2  2  6   0.0000  40.0366   3.1505   0.0000   1.1296   0.0000   1.1110
  6  2  6   0.0000   0.5047   0.8000   0.0000   0.8933   0.0000   4.6650
  2  6  6   0.0000   8.7037   0.0827   0.0000   3.5597   0.0000   1.1198
  3  6  3   0.0000   9.2317   0.1000   0.0000   1.0000   0.0000   1.0920
  6  3  6   0.0008  25.0000   8.0000   0.0000   1.0000   0.0000   3.0000
  2  3  6  66.0423   5.0000   1.0000   0.0000   1.0000   0.0000   1.2500
  2  6  3   0.0000   0.5000   0.1000   0.0000   1.0000   0.0000   3.0000
  3  3  6  70.0000  20.0000   1.0000   0.0000   1.0000   0.0000   1.2500
  3  7  3  90.0000  18.4167   0.6799  -8.0000   0.1310   0.0000   2.2321
  2  3  7  72.6004   9.6150   0.8905   0.0000   3.5473   0.0000   1.0400
  3  3  7  60.0000  40.0000   4.0000   0.0000   1.0000   0.0000   1.0400
  3  2  7   0.0000  10.0000   1.0000   0.0000   1.0000   0.0000   1.0400
  6  3  7  41.0995   3.2207   7.3523   0.0000   0.1101   0.0000   1.0947
  7  3  7  62.1312   7.5931   0.1000   0.0000   0.5154   0.0000   2.1744
  1  3  7  74.1394   8.5687   1.7132   0.0000  -0.6553   0.0000   2.2323
  2  7  3  75.0000  25.0000   2.0000   0.0000   1.0000   0.0000   1.2500
  3  7  7  70.0000  25.0000   2.0000   0.0000   1.0000   0.0000   1.2500
  3  9  3  90.0000  30.4624   2.1468   0.0000   0.0500   0.0000   1.9485
  9  3  9  90.0000   5.7486   5.0000   0.0000   2.0000   0.0000   1.1000
 10  9 10  79.8775  32.7635   1.6551   0.0000   1.0510   0.0000   1.6270
  9 10  9  28.5238  40.0000   5.0000   0.0000   2.0000   0.0000   1.1000
  3  3  9  62.9344  15.0215   4.3743   0.0000   0.6168   0.0000   1.1673
  3  9  9  33.7127   8.0623   3.4580   0.0000   0.0500   0.0000   2.6065
  2  3  9  90.0000   9.7766   8.0000   0.0000   0.0505   0.0000   1.7257
  1  3  9  90.0000   7.6430   0.2869   0.0000   1.8647   0.0000   4.0000
  3  2 10   0.0000   0.0100   0.0100   0.0000   0.0000   0.0000   1.1456
  1  1 11  75.8251  37.8489   6.6670   0.0000   0.9453   0.0000   2.9727
 11  1 11  77.8443  49.0744   5.9913   0.0000   0.7835   0.0000   2.3020
  1 11  1   0.0000  19.9962   3.2299   0.0000   2.1012   0.0000   1.1537
  1 11 11   0.0000  25.0000   1.0000   0.0000   1.0000   0.0000   1.0400
  2  1 11  73.2758   8.1380   1.8638   0.0000   1.0000   0.0000   1.2624
  3  1 11  70.0000  25.0000   2.0000   0.0000   1.0000   0.0000   1.2500
  1  4 11  74.3007  37.3795   6.7886   0.0000   1.4103   0.0000   3.0000
  4  1 11  83.0000  45.0000   7.5000   0.0000   1.4103   0.0000   1.7295
 11  7 11  91.0645  12.3538   1.4410   0.0000   1.3381   0.0000   1.0400
  3 12 12  87.8948  22.2413  10.1481   0.0000   3.4995   0.0000   1.0000
  3 12  3  86.0919  49.1734   0.7315   0.0000   1.0950   0.0000   1.7031
 12  3 12  45.0120   4.7492   1.8919   0.0000   3.2039   0.0000   2.9652
  3  3 12  53.2696   4.9197   4.1241   0.0000   2.7677   0.0000   2.9741
  2  3 12  97.4851  15.0320   0.4212   0.0000   0.3861   0.0000   1.1076
  1  3 12  53.7578  16.1143   0.8587   0.0000   3.2990   0.0000   1.2736
  1  1 12  59.2011  43.2290   0.3767   0.0000   0.9649   0.0000   1.5576
  1 12  3  97.8916  48.8646   0.9221   0.0000   3.4906   0.0000   1.1618
  1 12  1  91.3476  33.8293   1.0737   0.0000   3.4629   0.0000   1.1390
 12  1 12  40.0000  11.1752  12.0000   0.0000   2.9508   0.0000   1.0000
  1 12  4  86.3451  40.0000   0.8932   0.0000   3.5000   0.0000   1.0903
  2  1 12  47.4378  50.0000   0.1461   0.0000   2.7946   0.0000   2.3456
  2  4 12  93.7434   5.5568   0.5051   0.0000   3.5000   0.0000   1.2580
  1 12 11  88.0227  49.7009   0.6862   0.0000   3.3092   0.0000   1.2749
 12 12 12  87.5576  24.5425   1.8140   0.0000   0.0100   0.0000   4.0000
  1 12 12  90.0079  50.0000  12.0000   0.0000   0.6942   0.0000   1.0000
  3  1 12  40.0000  23.4630   0.5055   0.0000   0.9077   0.0000   1.9555
 12  4 12   6.2246  43.6926   3.9369   0.0000   2.7279   0.0000   1.2873
  1  4 12 100.0000  50.0000  12.0000   0.0000   3.5000   0.0000   1.0000
  4 12 12  53.7187  48.9782  12.0000   0.0000   0.9234   0.0000   1.0585
  7 11 12  20.9025  50.0000  11.9065   0.0000   3.4853   0.0000   1.1887
 11 13 11  74.1366  30.9566   2.4889   0.0000   1.2915   0.0000   1.2524
 12 11 13  22.3640  48.4752  11.3317   0.0000   3.4939   0.0000   1.2115
  4  3 12   5.8646  37.7873   9.6226   0.0000   2.9317   0.0000   2.3365
  3  4 12  99.8680  13.1862   4.4502   0.0000   3.0641   0.0000   2.9121
 58    ! Nr of torsions;at1;at2;at3;at4;;V1;V2;V3;V2(BO);vconj;n.u;n
  1  1  1  1   0.6309   5.0000   0.4566  -8.9659  -2.8212   0.0000   0.0000
  1  1  1  2   1.2741  42.6825   0.6113  -6.1044  -1.9450   0.0000   0.0000
  2  1  1  2   0.8525  32.5964   0.4237  -5.7199  -3.0000   0.0000   0.0000
  1  1  1  3   0.9963  17.2365   0.1491  -2.5000  -1.0000   0.0000   0.0000
  2  1  1  3   1.5159  28.6602   0.7169  -7.5489  -3.0000   0.0000   0.0000
  3  1  1  3  -0.2000  23.6540  -1.0000  -5.9155  -1.1552   0.0000   0.0000
  1  1  3  1   1.8231  46.5696  -1.0000  -3.0536  -3.0000   0.0000   0.0000
  1  1  3  2   1.4836  80.0000   0.0363  -4.7349  -1.0000   0.0000   0.0000
  2  1  3  1   0.5983  49.5033   0.7210  -3.4046  -1.6880   0.0000   0.0000
  2  1  3  2  -0.2000  76.3511   1.0000  -4.0709  -1.0000   0.0000   0.0000
  1  1  3  3  -0.2000   5.0000  -1.0000  -3.6523  -2.9000   0.0000   0.0000
  2  1  3  3   2.5000  80.0000   1.0000  -2.6071  -3.0000   0.0000   0.0000
  3  1  3  1  -0.2000  80.0000  -1.0000  -3.6863  -3.0000   0.0000   0.0000
  3  1  3  2   2.5000  38.8954  -0.8368  -4.6681  -2.9000   0.0000   0.0000
  3  1  3  3  -0.2000  78.1766   0.0250  -2.8895  -3.0000   0.0000   0.0000
  1  3  3  1   2.5000   0.1000   1.0000  -2.6905  -2.7573   0.0000   0.0000
  1  3  3  2   0.5241  69.2788  -1.0000  -4.4539  -2.8081   0.0000   0.0000
  2  3  3  2   2.5000   0.1000  -0.4869  -2.8372  -1.0000   0.0000   0.0000
  1  3  3  3   2.5000   0.1000   1.0000  -3.4298  -1.0000   0.0000   0.0000
  2  3  3  3  -0.2000   0.1000  -1.0000  -3.5698  -1.0000   0.0000   0.0000
  3  3  3  3  -0.2000   0.1000   1.0000  -3.8409  -1.0000   0.0000   0.0000
  0  1  2  0   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000
  0  2  2  0   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000
  0  2  3  0   0.0000   0.1000   0.0200  -2.5415   0.0000   0.0000   0.0000
  0  1  1  0   0.0000  50.0000   0.3000  -4.0000  -2.0000   0.0000   0.0000
  0  3  3  0   0.5511  25.4150   1.1330  -5.1903  -1.0000   0.0000   0.0000
  0  1  4  0   0.1198  59.9958   0.5626  -3.5954  -2.5000   0.0000   0.0000
  0  2  4  0  -1.5000   0.1032   0.0100  -5.0965   0.0000   0.0000   0.0000
  0  3  4  0   1.1397  61.3225   0.5139  -3.8507  -2.7831   0.0000   0.0000
  0  4  4  0   0.7265  44.3155   1.0000  -4.4046  -2.0000   0.0000   0.0000
  4  1  4  4  -0.0949   8.7582   0.3310  -7.9430  -2.0000   0.0000   0.0000
  0  1  5  0   3.3423  30.3435   0.0365  -2.7171   0.0000   0.0000   0.0000
  0  5  5  0  -0.0555  -5.0000   0.1515  -2.2056   0.0000   0.0000   0.0000
  0  2  5  0   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000
  2  3  5  3   2.5000   2.5000   0.2237 -10.0000  -1.0000   0.0000   0.0000
  0  3  5  0  -2.5000  50.0000  -0.5000 -10.0000  -1.0000   0.0000   0.0000
  0  6  6  0   0.0000   0.0000   0.1200  -2.4426   0.0000   0.0000   0.0000
  0  2  6  0   0.0000   0.0000   0.1200  -2.4847   0.0000   0.0000   0.0000
  0  3  6  0   0.0000   0.0000   0.1200  -2.4703   0.0000   0.0000   0.0000
  1  1  1  7   0.0000  19.3871   0.0103 -25.5765  -1.7255   0.0000   0.0000
  7  1  1  7   0.0000  80.5586   0.1104  -8.0928  -1.7255   0.0000   0.0000
  0  1  7  0   4.0000  45.8264   0.9000  -4.0000   0.0000   0.0000   0.0000
  0  7  7  0   4.0000  45.8264   0.9000  -4.0000   0.0000   0.0000   0.0000
  2  1  3  7  -1.5000  18.9285   0.3649  -6.1208   0.0000   0.0000   0.0000
  2  3  7  3   1.5000  -1.0000   0.2575  -6.2100   0.0000   0.0000   0.0000
  1  3  7  3  -1.4375  -0.8700   0.9861  -2.5424   0.0000   0.0000   0.0000
  7  3  7  3  -1.5000  21.5086  -1.0000  -4.8869   0.0000   0.0000   0.0000
  2  1  3  9   0.0000  84.3556   0.1000  -3.1953   0.0000   0.0000   0.0000
  1  1  3  9   0.0000  51.0461   0.1059  -7.2043   0.0000   0.0000   0.0000
  2  3  9  3  -0.2500   0.0100  -0.5000  -4.6984   0.0000   0.0000   0.0000
  1  1  1 11   0.5000   0.1000   0.4683 -11.5274  -1.7255   0.0000   0.0000
  2  1  1 11   0.0000  49.3871   0.2000 -10.5765  -1.7255   0.0000   0.0000
 11  1  1 11  -0.5000  95.4727  -0.2080  -4.8579  -1.7255   0.0000   0.0000
  0  1 11  0   1.0000  50.0000   0.9000  -3.0000   0.0000   0.0000   0.0000
  0 11 11  0   1.0000  50.0000   0.9000  -3.0000   0.0000   0.0000   0.0000
  9    ! Nr of hydrogen bonds;at1;at2;at3;Rhb;Dehb;vhb1
  3  2  3   2.1493  -3.8387   1.5230  28.0017
  3  2  4   1.5921  -3.9331   1.4500  19.5000
  4  2  3   1.4755  -3.8528   1.4500  19.5000
  4  2  4   1.8557  -6.0000   1.4500  19.5000
  3  2  5   1.5000  -2.0000   1.4500  19.5000
  4  2  5   1.5000  -2.0000   1.4500  19.5000
  5  2  3   1.5000  -2.0000   1.4500  19.5000
  5  2  4   1.5000  -2.0000   1.4500  19.5000
  5  2  5   1.5000  -2.0000   1.4500  19.5000
The title line of the force field says:
There is no mention of “Ti”. Are you sure the parameter set has been parameterized for “Ti”??
The fact that there is an entry for “Ti” in the parameter file has no meaning. Many times, people re-cycle parameter files and then just change/parameterize/replace some elements and leave the unparameterized entries in the file (for convenience).
Ah wonderful, that is probably the case - thank you
