I would like to use the ReaxFF parameterisation published here. Happily the authors have supplied the parameters in the supporting information. However, when using these parameters with LAMMPS (29 Oct 2020) I am getting the following error:
ERROR: Inconsistent force field file (…/reaxc_ffield.cpp:341)
Last command: pair_coeff * * Ostadhossein_2017_H_S_Mo.reaxff H S Mo
I’ve dug in to reaxc_ffield.cpp and line 341 is in the section which reads the two-body interactions. It seems to check that the atom numbers are positive integers and that the line contains enough parameters.
The relevant section of my force field file is
6 ! Nr of bonds; at1;at2;De(sigma);De(pi);De(pipi);p(be1);p(b p(be2);p(bo3);p(bo4);n.u.;p(bo1);p(bo2)
1 1 156.0973 0.0000 0.0000 -0.1377 0.0000 1.0000 6.0000 0.8240
2.9907 1.0000 0.0000 1.0000 -0.0593 4.8358 0.0000 0.0000
1 2 183.1582 0.0000 0.0000 -0.7544 0.0000 1.0000 6.0000 0.3725
11.7366 1.0000 0.0000 1.0000 -0.0595 4.6177 1.0000 0.0000
2 2 86.8868 69.1367 0.0000 -0.9993 -0.4781 1.0000 17.8574 0.0999
0.2799 -0.1677 8.2557 1.0000 -0.1131 6.1440 1.0000 0.0000
1 3 77.9675 0.0000 0.0000 -0.5019 -0.3000 0.0000 36.0000 0.1374
0.0697 -0.3027 15.0243 1.0000 -0.0500 5.9618 1.0000 0.0000
2 3 64.9870 33.5938 137.6546 1.0000 -0.2304 1.0000 19.1688 0.2000
1.3265 -0.1497 7.0000 1.0000 -0.1447 6.6437 1.0000 0.0000
3 3 51.8235 0.0000 0.0000 0.8271 -0.3000 0.0000 16.0000 0.2670
0.2248 -0.3000 16.0000 1.0000 -0.1908 7.3978 0.0000 0.0000
It looks to me like none of the conditions to throw the error would be met so I’m wondering what I’m missing here! Hopefully it’s a simple fix. Any help or guidance here would be much appreciated. Let me know if you need any more files or further information about the simulation.
