ReaxFF initial temperature spike (formatted)
Hi all,
Context:
I’m conducting MD simulations of the fluorination of bilayer graphene using the ReaxFF force field. My goal is to study the system at various temperatures (700K, 500K, 300K…) to observe C-F bonding. The graphene bilayer was built in VMD, and periodicity was manually verified and visualized in OVITO. It appeared structurally sound when I replicated the unit cell in both x and y directions.
The Problem
When I begin the simulation, the system is first minimized to 0 K. I then apply a thermostat to bring it to 700 K. While the temperature ramps correctly initially, I consistently observe a sharp temperature spike to ~830 K shortly after velocity initialization — even when fluorine atoms are not added, and even at very small timesteps (e.g., 0.1 fs). The spike later relaxes and the system stabilizes, but I’m trying to resolve this transient behavior. Below are some output lines showing this behavior (sorry for the crowded view):
Step Temp E_pair E_mol TotEng Press
58 700 -1190540.1 0 -1175752.6 92958.971
100 522.85601 -1186389.9 0 -1175344.6 67898.317
150 732.60283 -1190359.5 0 -1174883.3 29355.424
200 803.10733 -1191565.6 0 -1174599.9 19041.264
250 777.73721 -1191451 0 -1175021.3 16333.987
300 816.93246 -1193152.1 0 -1175894.4 15345.358
350 829.22071 -1194330.6 0 -1176813.3 13201.88
400 796.83794 -1194624 0 -1177790.8 10883.634
450 770.03978 -1194958.6 0 -1178691.5 8697.1269
500 768.01306 -1195783.1 0 -1179558.8 8110.3273
550 766.29399 -1196605.2 0 -1180417.3 7558.6894
600 753.48731 -1197179.8 0 -1181262.4 6456.0001
650 743.74551 -1197760.6 0 -1182048.9 5839.4056
700 740.67396 -1198429 0 -1182782.2 5036.8335
750 728.1488 -1198858.7 0 -1183476.6 5000.4342
800 720.16754 -1199329.6 0 -1184116.1 5154.1862
850 715.07721 -1199800 0 -1184694 5559.0157
900 701.42814 -1200011.8 0 -1185194.2 5787.4037
950 695.25765 -1200282.6 0 -1185595.3 5893.9998
What I’ve Tried So Far
  • Tested a wide range of timesteps: 0.1 fs, 0.25 fs, 0.5 fs, and 1 fs. The spike still appears, though slightly smaller at lower timesteps.
  • Ran the simulation without adding fluorine atoms to try and isolate the source — the spike persists, so the F atoms aren’t the root cause.
  • Verified the box bounds and structure replication manually and visually (VMD and OVITO). The geometry looks clean and periodic.
  • Checked that my ReaxFF file is suited for my system (link), which resulted in a way softer spike instead of ~1280 K previously.
Suspected Causes / Next Steps I’m Considering
Based on a 2015 paper by Jensen et al. (J. Comput. Chem., 36, 1587–1596), which explores the effect of timestep and thermostats on ReaxFF behavior in carbon systems, I’m thinking this temperature spike may be related to:
  • Lack of equilibration via Langevin damping or similar methods to smooth the transition from minimization to NVT
  • Localized stress or energy pockets forming in pristine carbon structures under thermal activation (they report similar ReaxFF effects in graphene and diamond)
  • Underlying graphene lattice issues that I should perhaps look into, maybe run tests using a simpler force field (e.g. AIREBO) to try and diagnose the problem?
So now I’m trying to decide my next step, if I should introduce a short equilibration phase before the NVT run? or are the other points listed worth looking into again?
Here is my script for reference:
# 1) Initialization
variable T equal 700  # Starting temperature
units real
atom_style charge
boundary p p f  # periodic in x and y, fixed in z
# Read graphene structure
read_data graphene.data
# Use ReaxFF
pair_style reaxff NULL safezone 3.0 mincap 150
pair_coeff * * ffield.reax.FC.txt C F
# 2) Addition of Fluorine atoms to system
# Define groups for Gr and F
group graphene type 1
group gas type 2
# Define regions for F atoms, above and below the graphene sheets
region above_graphene block 3 93 3 93 15 25 units box
region below_graphene block 3 93 3 93 -25 -15 units box
# Create fluorine atoms in the above and below regions
create_atoms 2 random 200 12345 above_graphene overlap 1.5
create_atoms 2 random 200 34134 below_graphene overlap 1.5
# Charge equilibration
fix qeq all qeq/reaxff 10 0.0 10.0 1.0e-6 reaxff maxiter 400
# Prevent atoms from leaving box along the z axis
fix wall all wall/reflect zlo EDGE zhi EDGE
compute tgraphene graphene temp
compute tgas gas temp
# Minimization and initialization of temperature
minimize 1.0e-6 1.0e-9 1000 10000
velocity all create ${T} 4928459 mom yes rot yes dist gaussian
# Output simulation data
dump mydmp all custom 500 dump.lammpstrj id type x y z q
thermo 50
# Full-system NVT simulation: apply one thermostat to the entire system
fix nvt_sim all nvt temp ${T} ${T} 50
# Monitor bond formation (all bonds)
fix reax_bonds all reaxff/bonds 50 bonds.reax
timestep 0.5
run 40000
LAMMPS version: 29 Aug 2024 - Update 1, on Windows
Thank you in advance! and apologies for any oversights
Look at the initial pressure of your system - it’s almost 100k atm. That is the cause of the spike. You can either use fix box/relax to rescale the simulation box during minimization or you need to change the lattice slightly.
BTW, you can generate graphene/graphite directly in LAMMPS with lattice custom.
Thank you! makes alot of sense. I incorporated the following line:
fix boxrelax all box/relax x 0.0 y 0.0 vmax 0.001
during minimization to remove initial in-plane strain (z is non-periodic). This reduced the pressure and resulted in a smoother temperature ramp-up:
Minimization
Step Temp E_pair E_mol TotEng Press Volume
0 0 -1183485.4 0 -1183485.4 115560.78 733717.82
13 0 -1217221.6 0 -1217221.6 -436.23642 749409.11
Simulation
13 700 -1217221.6 0 -1202434.1 465.76798
50 403.31942 -1210597.1 0 -1202077 8304.9709
100 372.65525 -1209342.5 0 -1201470.1 7843.6144
150 390.52826 -1208971.5 0 -1200721.6 7636.0776
200 457.01331 -1209544.2 0 -1199889.8 8597.4587
250 450.8263 -1208503 0 -1198979.3 9064.5159
300 478.14525 -1208117.1 0 -1198016.3 8971.5835
350 528.73883 -1208189.6 0 -1197020 8598.9853
400 530.62335 -1207192.2 0 -1195982.8 8516.1717
450 567.77546 -1206935.2 0 -1194940.9 7925.5055
500 600.63693 -1206597.9 0 -1193909.5 7429.8355
550 615.25972 -1205887 0 -1192889.7 7055.7509
600 652.55897 -1205710.3 0 -1191925 6569.43
650 648.20001 -1204708.6 0 -1191015.4 5876.2717
700 684.28042 -1204630.1 0 -1190174.7 4420.0693
750 713.46993 -1204540.5 0 -1189468.4 3285.4252
800 731.94132 -1204439.4 0 -1188977.2 2547.9991
I also tried non-zero pressures in x and y, the temperature trend seems to be the same. Not quite sure if the behavior right now is the norm or if I’m doing things incorrectly.
In addition, I have a question about generating graphene directly in LAMMPS. Would it have its pros compared to my current workflow with a dedicated .data file? e.g. avoiding lattice issues that I’m currently encountering? Just asking this preliminary question before going down that path and doing more reading.
Thanks again
In general temperatures should change smoothly during an MD simulation, since a rapidly changing temperature indicates very fast dynamics and we would assume (unless proven otherwise) that the integration timestep is too short.
This is not sufficient to prove that your MD simulation is valid. The logical argument:
Valid simulations have smoothly changing temperatures.
My simulation has smoothly changing temperature.
Therefore my simulation is a valid simulation.
has the same logical structure as
Spiders have eight legs.
Two cats have eight legs.
Therefore two cats are a spider.
:grin: Some things with eight legs are not spiders, and some simulations with smoothly changing temperatures may not be valid. It is up to you to know what you expect to see in your simulation and understand the results.
Regarding generating your graphite lattice inside the LAMMPS script: there is a small advantage, which is exactly what you identified. If the LAMMPS script can generate its own graphite lattice then there is no need to attach a separate data file for it. This doesn’t bring any performance benefits and the simulation should run the same, but it does mean that if you ever have to share the simulation setup (and you should! That’s how science works) that’s one file fewer to attach.
Another feature of using the LAMMPS script commands to generate the lattice is that any fault in your result can be traced to a few lines of script. By comparison, in a data file, there will be hundreds of lines specifying particle positions, and any of them could be wrong without you noticing. (You could also have an error in your LAMMPS lattice command – but that might be easier to debug.)
It is a minor priority, but it can be nice to have a simulation that needs only the LAMMPS input script and not a data file.
There’s not much to add to @srtee response. (: I would only point out that with lattice custom you can easily prepare a system with different size (or even make a graphene multilayer) by changing a single line (with region definition) in the input script.
Thank you both for the great insights! much appreciated
