I want to, in advance, say I’m not sure if this is something I should be asking here but I would appreciate it very much if you’d share your experience.
I am very familiar with ReaxFF and have developed several parameter sets myself, but for the life of me, I can’t figure out what is wrong with this file that I got from this paper:
https://pubs.acs.org/doi/10.1021/acs.jpcb.9b04298?src=getftr&utm_source=sciencedirect_contenthosting&getft_integrator=sciencedirect_contenthosting
NH3_x25.lmpdat (8.1 KB)
substrate_1slab2.lmpdat (161.0 KB)
in_1slab.input (2.3 KB)
COHN.reax (8.4 KB)
I have uploaded some files for you to reproduce. I get this error regarding the Atoms section of the file.
ERROR on proc 0: Not a valid floating-point number: ‘H’ (…/reaxff_ffield.cpp:584)
Last command: pair_coeff * * COHN.reax C O N C C C H H C N H
ORTE_ERROR_LOG: Out of resource in file …/…/…/orte/util/show_help.c at line 501
Which says probably it can’t parse the columns right and it think a floating number should be where ‘H’ atom type is defined.
Thank you very much and I understand if you respond with: this is not a LAMMPS problem.
