I am using reax force field for water molecules. I have taken parameters for water from the reference , 2017, 121 (24), pp 6021–6032.
I am facing the following problems.
once the simulation enters 1fs it’s showing the following warning and error message
WARNING: Fix qeq/reax CG convergence failed after 200 iterations at 151119 step (…/fix_qeq_reax.cpp:741)
ERROR: Lost atoms: original 12600 current 3862 (…/thermo.cpp:441)
Last command: run 50000
My system consists of 4120 water molecules which I calculated using the number density and box dimension is 505050 Angstrom cube
The following are my input script,qeq parameters are given below
Input script
units real
newton on
atom_style charge
read_data data.waterchrg
pair_style reax/c lmp_control2
pair_coeff * * ffield_reaxh2o H O
compute reax all pair reax/c
variable eb equal c_reax[1]
variable ea equal c_reax[2]
variable elp equal c_reax[3]
variable emol equal c_reax[4]
variable ev equal c_reax[5]
variable epen equal c_reax[6]
variable ecoa equal c_reax[7]
variable ehb equal c_reax[8]
variable et equal c_reax[9]
variable eco equal c_reax[10]
variable ew equal c_reax[11]
variable ep equal c_reax[12]
variable efi equal c_reax[13]
variable eqeq equal c_reax[14]
neighbor 2 bin
neigh_modify every 10 delay 0 check no
fix 2 all qeq/reax 1 0.0 10.0 1e-6 param.qeq
thermo 1000
thermo_style custom step temp epair etotal press v_eb v_ea v_elp v_emol v_ev v_epen v_ecoa v_ehb v_et v_eco v_ew v_ep v_efi v_eqeq
velocity all create 300.0 4712398
dump 1 all cfg 1000 *.cfg mass type xs ys zs
dump_modify 1 element H O
fix 3 all reax/c/species 1 10 1000 speciesRT.out element H O
dump 5 all xyz 1000 dump_reaxwatRT
timestep 0.1
fix 11 all nve
run 50000
unfix 11
timestep 0.25
fix 11 all nve
run 50000
unfix 11
timestep 0.50
fix 11 all nve
run 50000
unfix 11
timestep 1.00
fix 11 all nve
run 50000
unfix 11
1 5.8678 14.0000 0.9000 for Hydrogen
2 8.5000 17.9978 1.0500 for Oxygen
Water molecule was packed using packmol and data file was generated using vmd.
I was facing the same issue even after using xyz coordinates taken by equilibrating water molecules.
Expecting a solution to this issue.
Thank you
