What you are attempting to do is an excellent way to generate garbage results. If you read the ReaxFF papers by van Duin et al, you will see REAXFF is a STAND-ALONE force field and should not be combined with others. If you decide to ignore the limitations specifically stated by the original creators of REAXFF then you must perform exhaustive testing and comparison with other results to prove the combination of Force Fields you have unwisely chosen to use actually reproduces (and produces) correct results.
Any paper I get to review that tries to combine REAXFF with other force fields is subjected to extreme scrutiny and invariably rejected because the work was not done to prove the combine force fields generate correct results.
James Kress Ph.D., President
The KressWorks® Foundation
An IRS Approved 501 ©(3) Charitable, Nonprofit Organization
“Engineering The Cure” ©
(248) 605-8770
Learn More and Donate At:
Website: http://www.kressworks.org
Facebook: https://www.facebook.com/KressWorks.Foundation/
Twitter: @KressWorksFnd
Confidentiality Notice | This e-mail message, including any attachments, is for the sole use of the intended recipient(s) and may contain confidential or proprietary information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, immediately contact the sender by reply e-mail and destroy all copies of the original message.
