I’m new to lammps and I’ve written the following input script:
REAX potential for a bead spring polymer system
units real
atom_style charge
read_data data.polyethylene_100chains_100monomers_density0.95
pair_style reax 6.0 1 1 1.0e-6
pair_coeff * * ffield.reax 1 2
compute reax all pair reax
neighbor 0.3 bin
neigh_modify every 10 delay 0 check no
fix 1 all nve
fix 2 all temp/berendsen 300.0 300.0 100.0
fix 3 all reax/bonds 100 bonds.tatb
thermo 10
timestep 0.2
dump 1 all atom 30 dump.reax.polyethylene_100chains_100monomers.lammpstrj
run 100
The .data file was constructed via a polymer modeler and has been equilibrated . My question is if the reaxff is going to construct the initial structure(polyethylene), without changing it (because the only pair style that I could use was charge which does not contain bonds) plus the cross-links.
Many thanks in advance.
Mike
21.06.2013, 17:58, "Michael Papanikolaou" <[email protected]...>:
If by constructing the initial structure you mean determining bonding between monomers (and links between chains), whether Reax will find bonds or not depends on what parametrization of Reax you use and how did you construct and equilibrate your initial geometry. If atomic positions you have are more or less consistent with what would Reax give for polyethilene, bonds will be ok. Anyway, you have to check it. You may use fix reax/c/bonds and fix reax/c/species to see what you get.
Regards,
Oleg.
The input to ReaxFF is just atom positions so ReaxFF always tries to find bonds. A simple test is to read your structure into Lammps, run a minimization using ReaxFF and then a few steps of low temperature MD, output the structure and do a bond by bond comparison to your input structure. This will tell you if there are problems with the ReaxFF parameter file you are using, the input file structure or any other options set.
Kevin
