Dear Axel,
I tried to attached some file, but unfortunately being a new user I cannot do that, so I’m writing below the input LAMMPS script, log file, and initial and final part of tables.
If necessary, I’ll write the full tables (they are ~ 20 000 lines long).
Thank you for your time.
Kind regards,
Fabio
P.S.: using these tables with linear interpolation implies an error respect to the exact functional form of the potential of the same order of the functional form if using float.
Simulation NVE of bi-disperse system with pair_style
input.in:
# Binary additive repulsive harmonic in 3D
units lj
atom_style atomic
read_data config_equilibrated_T0.0005.dat
### VARIABLES ###
variable T1 equal 0.0005
variable dt equal 0.005 # LJ default = 0.005
variable Nrun equal 10000000
variable Nthermo equal ${Nrun}/1000
variable Ndump equal ${Nrun}/100
### PARAMETERS ###
mass * 1.0
pair_style harmonic/cut
pair_coeff 1 1 1.0 1.0
pair_coeff 1 2 1.0 1.2
pair_coeff 2 2 1.0 1.4
timestep ${dt}
fix 1 all nve
# Assigning random velocities Maxwell distributed at T=T1
velocity all create ${T1} 54321
run 0
velocity all scale ${T1}
thermo_style custom step temp press pe
thermo ${Nthermo}
dump 1 all atom ${Ndump} pos.dat
dump_modify 1 scale no
run ${Nrun}
log.lammps:
LAMMPS (17 Feb 2022)
OMP_NUM_THREADS environment is not set. Defaulting to 1 thread. (src/comm.cpp:98)
units lj
atom_style atomic
Reading data file ...
orthogonal box = (0 0 0) to (18.155025 18.155025 18.155025)
1 by 2 by 3 MPI processor grid
reading atoms ...
4000 atoms
read_data CPU = 0.006 seconds
### VARIABLES ###
variable Nthermo equal 10000000/1000
variable Ndump equal 10000000/100
### PARAMETERS ###
mass * 1.0
timestep ${dt}
timestep 0.005
fix 1 all nve
velocity all create 0.0005 54321
run 0
generated 0 of 1 mixed pair_coeff terms from geometric mixing rule
Neighbor list info ...
update every 1 steps, delay 10 steps, check yes
master list distance cutoff = 1.7
ghost atom cutoff = 1.7
binsize = 0.85, bins = 22 22 22
1 neighbor lists, perpetual/occasional/extra = 1 0 0
(1) pair harmonic/cut, perpetual
attributes: half, newton on
pair build: half/bin/atomonly/newton
stencil: half/bin/3d
bin: standard
Per MPI rank memory allocation (min/avg/max) = 3.117 | 3.117 | 3.119 Mbytes
Step Temp E_pair E_mol TotEng Press
0 0.0005 0.00044873224 0 0.0011985447 0.011035339
Loop time of 3.81917e-06 on 6 procs for 0 steps with 4000 atoms
82.9% CPU use with 6 MPI tasks x 1 OpenMP threads
MPI task timing breakdown:
Section | min time | avg time | max time |%varavg| %total
Pair | 0 | 0 | 0 | 0.0 | 0.00
Neigh | 0 | 0 | 0 | 0.0 | 0.00
Comm | 0 | 0 | 0 | 0.0 | 0.00
Output | 0 | 0 | 0 | 0.0 | 0.00
Modify | 0 | 0 | 0 | 0.0 | 0.00
Other | | 3.819e-06 | | |100.00
Nlocal: 666.667 ave 687 max 652 min
Histogram: 1 0 2 0 2 0 0 0 0 1
Nghost: 1032.33 ave 1060 max 1001 min
Histogram: 1 1 0 0 0 2 0 0 0 2
Neighs: 3793.33 ave 3925 max 3712 min
Histogram: 1 1 1 1 0 1 0 0 0 1
Total # of neighbors = 22760
Ave neighs/atom = 5.69
Neighbor list builds = 0
Dangerous builds = 0
velocity all scale 0.0005
thermo ${Nthermo}
thermo 10000
dump 1 all atom 100000 pos.dat
run ${Nrun}
run 10000000
Per MPI rank memory allocation (min/avg/max) = 4.143 | 4.144 | 4.145 Mbytes
Step Temp Press PotEng
0 0.0005 0.011035339 0.00044873224
10000 19.658166 13.302539 0.20109979
20000 75.966326 50.921819 0.18321388
30000 137.55744 92.078141 0.17662565
40000 201.19151 134.59502 0.16336673
50000 266.65984 178.34571 0.16396462
60000 333.79777 223.21087 0.15879781
70000 402.61639 269.1974 0.15421099
80000 472.86276 316.14078 0.15301772
90000 544.57066 364.0559 0.15114932
100000 617.55304 412.83028 0.14550086
110000 691.64192 462.33925 0.14361545
3100000 66502.333 44442.559 0.18280083
3110000 66879.59 44694.681 0.19483811
3120000 67258.712 44948.033 0.17833582
3130000 67637.775 45201.358 0.18770853
3140000 68018.381 45455.71 0.18850005
3150000 68399.488 45710.394 0.18461318
ERROR: Lost atoms: original 4000 current 3997 (src/thermo.cpp:435)
Last command: run ${Nrun}
Simulation NVE of bi-disperse system with tables
input.in:
units lj
atom_style atomic
### VARIABLES ###
### PARAMETERS ###
mass * 1.0
pair_style table linear 20000
pair_coeff 1 1 Table_lammps-potential_epsilon1_N20k_11.dat AA 1.0
pair_coeff 1 2 Table_lammps-potential_epsilon1_N20k_12.dat AB 1.2
pair_coeff 2 2 Table_lammps-potential_epsilon1_N20k_22.dat BB 1.4
timestep ${dt}
fix 1 all nve
run 0
thermo ${Nthermo}
run ${Nrun}
log.lammps:
units lj
atom_style atomic
reading atoms ...
4000 atoms
read_data CPU = 0.005 seconds
### VARIABLES ###
### PARAMETERS ###
mass * 1.0
WARNING: 9982 of 20000 force values in table AA are inconsistent with -dE/dr.
WARNING: Should only be flagged at inflection points (src/pair_table.cpp:465)
WARNING: 9962 of 20000 force values in table AB are inconsistent with -dE/dr.
WARNING: 9974 of 20000 force values in table BB are inconsistent with -dE/dr.
timestep ${dt}
timestep 0.005
fix 1 all nve
run 0
(1) pair table, perpetual
bin: standard
0 0.0005 0.0005783626 0 0.0013281751 0.01407435
Loop time of 3.234e-06 on 6 procs for 0 steps with 4000 atoms
103.1% CPU use with 6 MPI tasks x 1 OpenMP threads
Other | | 3.234e-06 | | |100.00
thermo ${Nthermo}
thermo 10000
run ${Nrun}
run 10000000
0 0.0005 0.01407435 0.0005783626
10000 0.00050282195 0.014172699 0.00057412447
20000 0.000499744 0.014163817 0.00057873735
30000 0.00049285284 0.014474179 0.00058907275
40000 0.00049964862 0.014226466 0.00057888114
50000 0.00049075864 0.014294125 0.00059221687
60000 0.00049603576 0.0141714 0.00058429815
70000 0.00050257565 0.014151142 0.00057449748
80000 0.000495562 0.014338538 0.00058500129
90000 0.00049429613 0.0142483 0.00058691007
100000 0.00050150504 0.014219893 0.00057610701
110000 0.0004958415 0.014308043 0.00058458982
9950000 0.00050087683 0.014307953 0.0005770781
9960000 0.00049839937 0.014213436 0.00058079255
9970000 0.0004997317 0.014119572 0.00057879861
9980000 0.00049935678 0.01436484 0.000579349
9990000 0.00049854215 0.014239987 0.00058056629
10000000 0.00050358524 0.014076311 0.00057300705
Loop time of 471.286 on 6 procs for 10000000 steps with 4000 atoms
Performance: 9166403.191 tau/day, 21218.526 timesteps/s
89.6% CPU use with 6 MPI tasks x 1 OpenMP threads
Pair | 166.38 | 178.43 | 193.44 | 73.8 | 37.86
Neigh | 7.8755 | 7.9921 | 8.2227 | 3.9 | 1.70
Comm | 205.96 | 218.03 | 228.16 | 60.3 | 46.26
Output | 0.051892 | 0.054067 | 0.063472 | 1.8 | 0.01
Modify | 34.573 | 35.134 | 35.587 | 5.9 | 7.45
Other | | 31.65 | | | 6.72
Nlocal: 666.667 ave 685 max 659 min
Histogram: 1 2 2 0 0 0 0 0 0 1
Nghost: 1035.83 ave 1060 max 1022 min
Histogram: 2 1 0 0 1 1 0 0 0 1
Neighs: 3799.83 ave 3895 max 3758 min
Histogram: 3 1 0 0 0 0 1 0 0 1
Total # of neighbors = 22799
Ave neighs/atom = 5.69975
Neighbor list builds = 28749
Total wall time: 0:07:51
TABLES:
file: Table_lammps-potential_epsilon1_N20k_11.dat
# Table for repulsive harmonic potential. sigma_AA=1.0; sigma_AB=1.2; sigma_BB=1.4
AA
N 20000
1 0.100045 0.809919 1.799910
2 0.100090 0.809838 1.799820
3 0.100135 0.809757 1.799730
4 0.100180 0.809676 1.799640
5 0.100225 0.809595 1.799550
6 0.100270 0.809514 1.799460
7 0.100315 0.809433 1.799370
8 0.100360 0.809352 1.799280
9 0.100405 0.809271 1.799190
10 0.100450 0.809190 1.799100
19991 0.999595 0.000000 0.000810
19992 0.999640 0.000000 0.000720
19993 0.999685 0.000000 0.000630
19994 0.999730 0.000000 0.000540
19995 0.999775 0.000000 0.000450
19996 0.999820 0.000000 0.000360
19997 0.999865 0.000000 0.000270
19998 0.999910 0.000000 0.000180
19999 0.999955 0.000000 0.000090
20000 1.000000 0.000000 0.000000
file: Table_lammps-potential_epsilon1_N20k_12.dat
AB
N 20000
1 0.100055 1.209879 2.199890
2 0.100110 1.209758 2.199780
3 0.100165 1.209637 2.199670
4 0.100220 1.209516 2.199560
5 0.100275 1.209395 2.199450
6 0.100330 1.209274 2.199340
7 0.100385 1.209153 2.199230
8 0.100440 1.209032 2.199120
9 0.100495 1.208911 2.199010
10 0.100550 1.208790 2.198900
19991 1.199505 0.000000 0.000990
19992 1.199560 0.000000 0.000880
19993 1.199615 0.000000 0.000770
19994 1.199670 0.000000 0.000660
19995 1.199725 0.000000 0.000550
19996 1.199780 0.000000 0.000440
19997 1.199835 0.000000 0.000330
19998 1.199890 0.000000 0.000220
19999 1.199945 0.000000 0.000110
20000 1.200000 0.000000 0.000000
file: Table_lammps-potential_epsilon1_N20k_22.dat
BB
N 20000
1 0.100065 1.689831 2.599870
2 0.100130 1.689662 2.599740
3 0.100195 1.689493 2.599610
4 0.100260 1.689324 2.599480
5 0.100325 1.689155 2.599350
6 0.100390 1.688986 2.599220
7 0.100455 1.688817 2.599090
8 0.100520 1.688648 2.598960
9 0.100585 1.688479 2.598830
10 0.100650 1.688311 2.598700
19991 1.399415 0.000000 0.001170
19992 1.399480 0.000000 0.001040
19993 1.399545 0.000000 0.000910
19994 1.399610 0.000000 0.000780
19995 1.399675 0.000000 0.000650
19996 1.399740 0.000000 0.000520
19997 1.399805 0.000000 0.000390
19998 1.399870 0.000000 0.000260
19999 1.399935 0.000000 0.000130
20000 1.400000 0.000000 0.000000
