Dear lammps users
I utilize the “MPICH3” and “FFTW2” to compile the LAMMPS (version 1Feb14). The r23 cutoff does not exist in LAMMPS version of the SW potential. Therefore, I have obtained the r23 implemented version of LAMMPS modules pair_sw.cpp in the “Thermal transport properties of MoS2 and MoSe2 monolayers” paper, such as “pair_sw-MoSe2.cpp” and “pair_sw-MoS2.cpp” in the e-mail attachment. Then recompile LAMMPS by replacing the default pair_sw.cpp module. When I only replaced one file with the original one provided by LAMMPS, and then will be recompiled successfully. However, the two SW potentials need to be used in my research at the same time. When I replace two files “pair_sw-MoSe2.cpp” and “pair_sw-MoS2.cpp” and then recompile the LAMMPS, there are some errors as follows. I have tried many times by modifying some code, and a part of errors have been reduced, but still failed. Can you give me some suggestions? Thank you!
Dan Han
Here are the all errors:
pair_sw-MoSe2.o:in the function ‘LAMMPS_NS::Pair::compute_inner()’:
/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi/…/pair_sw-MoSe2.cpp:213: `LAMMPS_NS::PairSW::allocate()'is defined multiple times
pair_sw-MoS2.o:/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi/…/pair_sw-MoS2.cpp:213:is firstly defined here
pair_sw-MoSe2.o:in the function ‘LAMMPS_NS::PairSW::init_one(int, int)’:
/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi/…/pair_sw-MoSe2.cpp:327: `LAMMPS_NS::PairSW::init_one(int, int)'is defined multiple times
pair_sw-MoS2.o:/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi/…/pair_sw-MoS2.cpp:327:is firstly defined here
pair_sw-MoSe2.o:in the function ‘LAMMPS_NS::PairSW::init_style()’:
/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi/…/pair_sw-MoSe2.cpp:309: `LAMMPS_NS::PairSW::init_style()'is defined multiple times
pair_sw-MoS2.o:/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi/…/pair_sw-MoS2.cpp:309:is firstly defined here
pair_sw-MoSe2.o:in the function ‘LAMMPS_NS::PairSW::settings(int, char**)’:
/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi/…/pair_sw-MoSe2.cpp:229: `LAMMPS_NS::PairSW::settings(int, char**)'is defined multiple times
pair_sw-MoS2.o:/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi/…/pair_sw-MoS2.cpp:229:is firstly defined here
pair_sw-MoSe2.o:in the function ‘LAMMPS_NS::PairSW::~PairSW()’:
/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi/…/pair_sw-MoSe2.cpp:59: `LAMMPS_NS::PairSW::~PairSW()'is defined multiple times
pair_sw-MoS2.o:/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi/…/pair_sw-MoS2.cpp:59:is firstly defined here
pair_sw-MoSe2.o:in the function ‘LAMMPS_NS::PairSW::PairSW(LAMMPS_NS::LAMMPS*)’:
/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi/…/pair_sw-MoSe2.cpp:41: `LAMMPS_NS::PairSW::PairSW(LAMMPS_NS::LAMMPS*)'is defined multiple times
pair_sw-MoS2.o:/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi/…/pair_sw-MoS2.cpp:41:is firstly defined here
pair_sw-MoSe2.o:in the function ‘LAMMPS_NS::PairSW::read_file(char*)’:
/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi/…/pair_sw-MoSe2.cpp:336: `LAMMPS_NS::PairSW::read_file(char*)'is defined multiple times
pair_sw-MoS2.o:/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi/…/pair_sw-MoS2.cpp:336:is firstly defined here
pair_sw-MoSe2.o:in the function ‘LAMMPS_NS::PairSW::setup()’:
/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi/…/pair_sw-MoSe2.cpp:464: `LAMMPS_NS::PairSW::setup()'is defined multiple times
pair_sw-MoS2.o:/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi/…/pair_sw-MoS2.cpp:464:is firstly defined here
pair_sw-MoSe2.o:in the function ‘LAMMPS_NS::PairSW::coeff(int, char**)’:
/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi/…/pair_sw-MoSe2.cpp:237: `LAMMPS_NS::PairSW::coeff(int, char**)'is defined multiple times
pair_sw-MoS2.o:/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi/…/pair_sw-MoS2.cpp:237:is firstly defined here
pair_sw-MoSe2.o:in the function ‘LAMMPS_NS::PairSW::twobody(LAMMPS_NS::PairSW::Param*, double, double&, int, double&)’:
/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi/…/pair_sw-MoSe2.cpp:542: `LAMMPS_NS::PairSW::twobody(LAMMPS_NS::PairSW::Param*, double, double&, int, double&)'is defined multiple times
pair_sw-MoS2.o:/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi/…/pair_sw-MoS2.cpp:542:is firstly defined here
pair_sw-MoSe2.o:in the function ‘LAMMPS_NS::PairSW::threebody(LAMMPS_NS::PairSW::Param*, LAMMPS_NS::PairSW::Param*, LAMMPS_NS::PairSW::Param*, double, double, double*, double*, double*, double*, int, double&)’:
/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi/…/pair_sw-MoSe2.cpp:563: `LAMMPS_NS::PairSW::threebody(LAMMPS_NS::PairSW::Param*, LAMMPS_NS::PairSW::Param*, LAMMPS_NS::PairSW::Param*, double, double, double*, double*, double*, double*, int, double&)'is defined multiple times
pair_sw-MoS2.o:/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi/…/pair_sw-MoS2.cpp:563:is firstly defined here
pair_sw-MoSe2.o:in the function ‘LAMMPS_NS::PairSW::compute(int, int)’:
/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi/…/pair_sw-MoSe2.cpp:77: `LAMMPS_NS::PairSW::compute(int, int)'is defined multiple times
pair_sw-MoS2.o:/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi/…/pair_sw-MoS2.cpp:77:is firstly defined here
collect2: error: ld returned 1 exit status
Makefile:89: recipe for target ‘…/lmp_mpi’ failed
make[1]: *** […/lmp_mpi] Error 1
make[1]: Leave the directory “/home/sts/software/test/3/lammps-1Feb14/src/Obj_mpi”
Makefile:77: recipe for target ‘mpi’ failed
make: *** [mpi] Error 2
pair_sw-MoS2.cpp (17.9 KB)
pair_sw-MoSe2.cpp (17.9 KB)
