Dear lammps user.
What are the commands and methods to reduce the oscillation after my simulation results come out? I am desperately waiting.
Sincerely.
Long
------------------------ INITIALIZATION -----------------------------------------------
atom_style full
atom_modify map array sort 0 0.0
comm_modify vel yes
----------------- ATOMS DEFINITION ---------------------------------------------
read_data data.lammps
------------------------ FORCE FIELDS -------------------------------------------------
kspace_style pppm 1.0e-5
pair_style buck/coul/long 8.0 12.0 12.0
pair_coeff * * 0.00 0.100000 0.000000
pair_coeff 1 3 897459.51 0.420094 0.000000
pair_coeff 2 3 96327.40 0.375684 0.000000
pair_coeff 3 3 7529.17 0.985672 0.000000
neighbor 2.0 bin
------------------------ INITIAL VELOCITIES -------------------------------------------
velocity all create 200 12345 mom yes rot no
------------------------- THERMALIZATION ----------------------------------------------
min_style sd
minimize 1e-8 1e-9 8000 9000
#--------------------------THERMO INFORMATION SHOWS--------------------------------------
thermo_style custom step temp etotal ke pe cella cellb cellc cellalpha cellbeta cellgamma vol press v_dipole_x v_dipole_y v_dipole_z
#--------------------------RELAXTION PROCESS---------------------------------------------
timestep 0.0004
fix 1 all npt temp 200 200 0.04 tri 1.0 1.0 0.04
thermo 2500
dump D1 all custom 500 dumps/stab1_*.txt id type x y z q
dump_modify D1 sort id element Sr Ti O
run 200000
unfix 1
undump D1
#--------------------------ELECTRIC FIELD------------------------------------------------
reset_timestep 0
timestep 0.0004
variable modE equal 1.8e-2cos((2.0PI*ceil(step/250)*250)/2500)
fix Etetra all efield 0 0 v_modE
fix 2 all npt temp 200 200 0.04 tri 1.0 1.0 0.04
fix med all ave/time 25 100 2500 v_modE file HyL.txt
thermo 2500
dump D2 all custom 500 dumps/stab2_*.txt id type x y z q
dump_modify D2 sort id element Sr Ti O
run 500000
write_restart bt_cs.rst
