Dear All,
I am using LJ interaction potential parameters to determine the transport properties of CO2 at room temperature and pressure. Can I use the same potential parameters at high temperatures and pressures (Phase change of CO2)? Also, in some application there is a phase change during the process, so at that time will the same potential parameters validates the actual transport properties?
Please help! Thanks.
Dear All,
whether a potential is applicable for your specific simulation
conditions is for you to find out.
you can look at the publication describing the parameters you are
using to see what they are intended for, and then you can make tests
to a) confirm, that you can reproduce these stated properties and then
b) test, whether those parameters are transferable to other conditions
you are interested in, or rather how well. all empirical parameters
will only match certain properties well and others less so, even at
intended conditions. it is up to you, to make an assessment (and
justify it in any publication) as to how representative is for your
own purposes.
for a compound as commonly and frequently studied as CO2, there should
be a wealth of published information.
