Regarding bond coefficient parameters of TIP4P water model
Dear Sir,
I like to know what would be the bond and angle coefficient values of TIP4P water model. In Lammps manual bond length and angle values are given but K values are not provided. Some of the example input file shows the K values to be zero. Is it Ok?
Because from the expression of harmonic bond/angle style, it appears that K =0 means, force due to bond and angle parameters becomes zero.
I will be grateful if can clarify this thing.
Thanks in advance
Dear Sir,
TIP4P is a rigid water potential. thus force constants are irrelevant,
since the geometry has to be held rigid via fix shake or rattle or
rigid
