I have used the following creep deformation code. Sample is suppose AB2 alloy
echo both
atom_style atomic
read_data finalalloy.lmp
timestep 0.002
pair_style eam/alloy
pair_coeff * * Pot.EAM A B
thermo 100
velocity all create 1265.0 873847 rot yes mom yes dist gaussian
Energy minimization
min_style cg
minimize 1.0e-10 1.0e-10 10000 1000
variable tmp equal lx
variable lo equal ${tmp}
variable strain equal (lx-v_lo)/v_lo
variable time equal “step* 0.0002”
variable xhigh equal xhi
variable xlow equal xlo
variable zhigh equal zhi
variable zlow equal zlo
variable p1 equal “-pxx/10000”
variable p2 equal “-pyy/10000”
variable p3 equal “-pzz/10000”
Equilibration
fix equi all nvt temp 1265 1265 0.01
run 10000
unfix equi
initializing velocities
thermo_style custom step temp xlo xhi ylo yhi zlo zhi pe etotal press pxx vol
dump 1 all custom 10000 creep_dump@1265K*.lammpstrj id type x y z
log [email protected]
fix 3 all nve
fix def all print 500 "{time} {strain} {xlow} {xhigh} " file creep_curve_data.txt screen no
fix 7 all press/berendsen x 30000 30000 100 dilate all
run 500000
This code is running, but problem is that the temerature fluctuates.It is not at 1265 K. It continuously increases. I use nvt and nve. Instead of nve I am trying with nvt also but then creep curve is not coming.
where should I change. Any help is highly appreciated
