Dear LAMMPS Users,
I am trying to understand electrostatic interactions using LJ/Cut/Col/Cut without using kspace long-range interactions. In this process I have simulated the system at different force cut-off distances. My simulation system size is 77 Å and I should be able use a cut-off distance of 38.5 Å (half of the box size). However, with above 30 Å I am getting neighbour list overflow error. I would be grateful if someone could let me know how I can increase the cut-off distance to 38.5.
Sincerely,
Sada
Dear LAMMPS Users,
LAMMPS is not subject to the restriction of minimum image conventions,
so even cutoffs larger than half the minimum box diameter are
supported.
of course, having a dense system with a large cutoff will result in
very large neighbor lists (they grow O(N**3) for obvious reasons). so
you have to adjust the way how LAMMPS reserves space for them. please
see the documentation for the neigh_modify command (options one and
page). please also study the neighbor list summary information at the
end of each run for information about the size of neighbor lists.
