Dear all LAMMPS users,
While I am running the lammps code for the evaluation of thermal conductivity of Graphene with 20000 atoms with dimension box 200 X 100 X 2 having 2D layer with Tersoff potential I am getting the error like “Non Numeric positions-Simulation Unstable” during the simulation. I would like to know the reason and How can fix the problem. Please refer the input scripts here below.
Sample Graphene_tersoff
For thermal conductivity
Sample Graphene:
Input for energy minimization
#------------------------INITIALIZATION----------------------------
atom_style atomic
#-----------------------ATOM DEFINITION----------------------------
Generating a graphene structure
lattice custom 2.425 a1 1 0 0 a2 0 1.73203 0 a3 0.0 0.0 4 &
basis 0 0 0 basis 0.5 0.16666666666666666 0 basis 0.5 0.5 0 basis 0 0.6666666666666666 0
C atoms region
region grap block 0 100 0 50 0.5 1.5
Simulation box size
region boundary block 0 100 0 50 0 2
Combine regions
region whole union 2 grap boundary
Create viewing box
create_box 1 boundary
Creating C atoms
create_atoms 1 region grap
mass 1 12
group sample region grap
#------------------------FORCE FIELDS------------------------------
Interaction potential for silicon atoms
pair_style tersoff
pair_coeff * * BNC.tersoff C
neighbor 1.0 bin
neigh_modify delay 0 every 1 check yes page 500000 one 50000
#-------------------------SIMULATION PROCESS---------------------------------
Initial velocities at a given temperature
velocity all create 300 458273253 dist gaussian
Timestep to make the integration of the motion equation
timestep 0.001
Parameters to print out on the screen and log.lammps file
thermo_style custom step temp etotal vol lx ly lz press pxx pyy pzz cpu
thermo 1000
Saving atomic coordinates
dump 1 all custom 1000 [email protected]…7498…*.lammpstrj id type x y z
Energy minimization parameters
min_style cg
minimize 1.0e-10 1.0e-12 100000 10000
#-----SIMULATION DONE-------
print "Simulation complete
- For the evaulation of thermal conductivity:
Sample LAMMPS input script for thermal conductivity of Graphene
units real
variable T equal 300
variable V equal vol
variable dt equal 2.0
variable p equal 200 # correlation length
variable s equal 10 # sample interval
variable d equal $p*$s # dump interval
convert from LAMMPS real units to SI
variable kB equal 1.3806504e-23 # [J/K] Boltzmann
variable kCal2J equal 4186.0/6.02214e23
variable A2m equal 1.0e-10
variable fs2s equal 1.0e-15
variable convert equal {kCal2J}*{kCal2J}/{fs2s}/{A2m}
setup problem
atom_style atomic
read_data Sample_Graphene_Tersoff
mass 1 12.0
pair_style tersoff
timestep ${dt}
thermo $d
equilibration and thermalization
velocity all create 300 102486 mom yes rot yes dist gaussian
fix NVT all nvt temp $T $T 0.01 drag 0.2
run 8000
#thermal conductivity calculation, switch to NVE if desired
unfix NVT
fix NVE all nve
reset_timestep 0
compute myKE all ke/atom
compute myPE all pe/atom
compute myStress all stress/atom NULL virial
compute flux all heat/flux myKE myPE myStress
variable Jx equal c_flux[1]/vol
variable Jy equal c_flux[2]/vol
variable Jz equal c_flux[3]/vol
fix JJ all ave/correlate $s $p d &
c_flux[1] c_flux[2] c_flux[3] type auto file J0Jt.dat ave running
variable scale equal {convert}/${kB}/$T/$T/$V*s*{dt}
variable k11 equal trap(f_JJ[3]){scale}
variable k22 equal trap(f_JJ[4])*{scale}
variable k33 equal trap(f_JJ[5])${scale}
thermo_style custom step temp v_Jx v_Jy v_Jz v_k11 v_k22 v_k33
dump 7 all custom 2000 Graphene_thermal_deform*.lammpstrj id type x y z
run 100000
variable k equal (v_k11+v_k22+v_k33)/3.0
variable ndens equal count(all)/vol
print “average conductivity: $k[W/mK] @ T K, {ndens} /A^3”
