Hello
Iam trying to make a group of atoms immobile which are in the region 4.371 5.629 4.371 5.629 4.371 5.629 units lattice through out the simulation but when iam visualizing with Ovito i can see them moving.Could yoou please let me know where iam i going wrong.The following is my code :
---------- Initialize Simulation ---------------------
clear
atom_style atomic
atom_modify map array
---------- Create Atoms ---------------------
lattice fcc 4
region box block 0 10 0 10 0 10 units lattice
region nuc block 4.371 5.629 4.371 5.629 4.371 5.629 units lattice
create_box 4 box
lattice fcc 4 orient x 1 0 0 orient y 0 1 0 orient z 0 0 1
create_atoms 4 box
#replicate 20 20 20
set region box type/fraction 1 0.25 12541567
set region box type/fraction 2 0.25 12543796
set region box type/fraction 3 0.25 12541522
set region box type/fraction 4 0.25 12145
group nucleus region nuc
---------- Define Interatomic Potential ---------------------
pair_style eam/alloy
pair_coeff * * CoFeNiPd.set Co Fe Ni Pd
neighbor 2.0 bin
neigh_modify every 1 check yes
timestep 0.002 #from jafray 0.002 picometers
velocity all create 300 12345 mom yes rot yes
---------- calculatingcentro symmetry to know whether the atom is distorted or not---------------------
compute csym all centro/atom fcc
compute peratom all pe/atom
compute pattern all cna/atom 3.414
#reset_timestep 0
thermo 10
thermo_style custom step temp etotal ke pe lx ly lz press pxx pyy pzz enthalpy
---------- Run Minimization ---------------------
dump 2 all custom 50 dump.ten.* id type xs ys zs c_csym c_peratom c_pattern
dump_modify 2 element Co Fe Ni Pd
fix 1 nucleus setforce 0 0 0
fix 2 all npt temp 300 2300 0.2 iso 0 0 1
run 300
undump 2
unfix 2
write_data heat.dat
write_restart heating.rest
dump 3 all custom 50 dump.f* id type xs ys zs c_csym c_peratom c_pattern
dump_modify 3 element Co Fe Ni Pd
fix 3 all nvt temp 2300 2300 0.2 iso 0 0 1
run 500
undump 3
unfix 3
write_data 10homo.dat
write_restart 10homo.rest
dump 4 all custom 50 dump.f* id type xs ys zs c_csym c_peratom c_pattern
dump_modify 4 element Co Fe Ni Pd
fix 4 all nvt temp 2300 2200 0.2
run 500
undump 4
unfix 4
write_data 10p2200.dat
write_restart 10p2200.rest
dump 5 all custom 50 dump.f* id type xs ys zs c_csym c_peratom c_pattern
dump_modify 5 element Co Fe Ni Pd
fix 5 all nvt temp 2200 2100 0.2
run 500
undump 5
unfix 5
write_data 10p2100.dat
write_restart 10p2100.rest
dump 6 all custom 50 dump.f* id type xs ys zs c_csym c_peratom c_pattern
dump_modify 6 element Co Fe Ni Pd
fix 6 all nvt temp 2100 2000 0.2
run 500
undump 6
unfix 6
write_data 10p2000.dat
write_restart 10p2000.rest
dump 7 all custom 50 dump.f* id type xs ys zs c_csym c_peratom c_pattern
dump_modify 7 element Co Fe Ni Pd
fix 7 all nvt temp 2000 1900 0.2
run 500
undump 7
unfix 7
write_data 10p1900.dat
write_restart 10p1900.rest
dump 8 all custom 500 dump.f* id type xs ys zs c_csym c_peratom c_pattern
dump_modify 8 element Co Fe Ni Pd
fix 8 all nvt temp 1900 1800 0.2
run 500
undump 8
unfix 8
write_data 10p1800.dat
write_restart 10p1800.rest
dump 9 all custom 500 dump.f* id type xs ys zs c_csym c_peratom c_pattern
dump_modify 9 element Co Fe Ni Pd
fix 9 all nvt temp 1800 1700 0.2
run 500
undump 9
unfix 9
write_data 10p1700.dat
write_restart 10p1700.rest
dump 10 all custom 500 dump.f* id type xs ys zs c_csym c_peratom c_pattern
dump_modify 10 element Co Fe Ni Pd
fix 10 all nvt temp 1700 1600 0.2
run 500
undump 10
unfix 10
write_data 10p1600.dat
write_restart 10p1600.rest
dump 11 all custom 500 dump.f* id type xs ys zs c_csym c_peratom c_pattern
dump_modify 11 element Co Fe Ni Pd
fix 11 all nvt temp 1600 1500 0.2
run 500
undump 11
unfix 11
write_data 10p1500.dat
write_restart 10p1500.rest
dump 12 all custom 500 dump.f* id type xs ys zs c_csym c_peratom c_pattern
dump_modify 12 element Co Fe Ni Pd
fix 12 all nvt temp 1500 1400 0.2
run 500
undump 12
unfix 12
write_data 10p1400.dat
write_restart 10p1400.rest
dump 13 all custom 500 dump.f* id type xs ys zs c_csym c_peratom c_pattern
dump_modify 13 element Co Fe Ni Pd
fix 13 all nvt temp 1400 1300 0.2
run 500
undump 13
unfix 13
write_data 10p1300.dat
write_restart 10p1300.rest
dump 14 all custom 500 dump.f* id type xs ys zs c_csym c_peratom c_pattern
dump_modify 14 element Co Fe Ni Pd
fix 14 all nvt temp 1300 1200 0.2
run 500
undump 14
unfix 14
write_data 10p1200.dat
write_restart 10p1200.rest
dump 15 all custom 500 dump.f* id type xs ys zs c_csym c_peratom c_pattern
dump_modify 15 element Co Fe Ni Pd
fix 15 all nvt temp 1200 1100 0.2
run 500
undump 15
unfix 15
write_data 10p1100.dat
write_restart 10p1100.rest
dump 16 all custom 500 dump.f* id type xs ys zs c_csym c_peratom c_pattern
dump_modify 16 element Co Fe Ni Pd
fix 16 all nvt temp 1100 1000 0.2
run 500
undump 16
unfix 16
write_data 10p1000.dat
write_restart 10p1000.rest
dump 17 all custom 500 dump.f* id type xs ys zs c_csym c_peratom c_pattern
dump_modify 17 element Co Fe Ni Pd
fix 17 all nvt temp 1000 900 0.2
run 500
undump 17
unfix 17
write_data 10p900.dat
write_restart 10p900.rest
dump 18 all custom 500 dump.f* id type xs ys zs c_csym c_peratom c_pattern
dump_modify 18 element Co Fe Ni Pd
fix 18 all nvt temp 900 800 0.2
run 500
undump 18
unfix 18
write_data 10p800.dat
write_restart 10p800.rest
dump 19 all custom 500 dump.f* id type xs ys zs c_csym c_peratom c_pattern
dump_modify 19 element Co Fe Ni Pd
fix 19 all nvt temp 800 700 0.2
run 500
undump 19
unfix 19
write_data 10p700.dat
write_restart 10p700.rest
dump 20 all custom 500 dump.f* id type xs ys zs c_csym c_peratom c_pattern
dump_modify 20 element Co Fe Ni Pd
fix 20 all nvt temp 700 600 0.2
run 500
undump 20
unfix 20
write_data 10p600.dat
write_restart 10p600.rest
dump 21 all custom 500 dump.f* id type xs ys zs c_csym c_peratom c_pattern
dump_modify 21 element Co Fe Ni Pd
fix 21 all nvt temp 600 500 0.2
run 500
undump 21
unfix 21
write_data 10p500.dat
write_restart 10p500.rest
dump 22 all custom 500 dump.f* id type xs ys zs c_csym c_peratom c_pattern
dump_modify 22 element Co Fe Ni Pd
fix 22 all nvt temp 500 400 0.2
run 500
undump 22
unfix 22
write_data 10p400.dat
write_restart 10p400.rest
dump 23 all custom 500 dump.f* id type xs ys zs c_csym c_peratom c_pattern
dump_modify 23 element Co Fe Ni Pd
fix 23 all nvt temp 400 300 0.2
run 500
undump 23
unfix 23
write_data 10p300.dat
write_restart 10p300.rest
dump 24 all custom 250 dump.f* id type xs ys zs c_csym c_peratom c_pattern
dump_modify 24 element Co Fe Ni Pd
fix 24 all nvt temp 300 300 0.2
run 250
undump 24
unfix 24
write_data 300homo.dat
write_restart 300homo.rest
unfix 1
Sincerely
M.Maheshwari
School of Minerals,Metallurgical and Materials Engineering
Indian Institute of Technology,Bhubaneswar
