Hi everyone,
I’m trying to simulate a tension test on Al sample. I want to change the orientation of a region within the simulation box.
The problem is that I couldn’t determine orient values for x and y in case the orient z is 1 2 3. I derived some values by coordinate transformation. However, I got the error “Lattice orient vectors are not right-handed.”
Does anyone know how can i proceed?
Thanks in advance,
Berkay
Hi everyone,
I'm trying to simulate a tension test on Al sample. I want to change the
The problem is that I couldn't determine orient values for x and y in case
However, I got the error "Lattice orient vectors are not right-handed."
If u are trying to compress in z-[123] direction, then choose x direction
arbitrarily such that x.z=0, then choose y direction such that x X y=z.
This is what it means by right handed.
Thanks for the answer. I tried
x -1 2 -1 y -1.5 0 0.5 z 1 2 3
I got “Lattice orient vectors are not orthagonal” error.
I think I have to select these values such that x.y=0, y.z=0 as well.
Do you have any other suggestion?
Berkay
I got "Lattice orient vectors are not orthagonal" error.
Yes... After all, this is what you want. U should have x.y=0, x.z=0,y.z=0
and x X y =z.
