For thermal conductivity calculation of Diamond (111), I have this triclinic structure.
0.0 277.4474877 xlo xhi
0.0 432.49783068 ylo yhi
0.0 18.2376 zlo zhi
249.70273902 0.0 0.0 xy xz yz
The figure shows how I defined the source and sink regions. For your kind reference, I am giving the details of my heat layers.
heat layers
region hot_end prism 0 277.447 0 10 0 18.2376 249.70 0.0 0.0
region cold_end prism 0 277.447 422.498 432.498 0 18.2376 249.70 0.0 0.0
region fixed_heat_source_side prism 0 277.447 10 30 4 14 249.70 0.0 0.0
region fixed_heat_sink_side prism 0 277.447 402 422.498 4 14 249.70 0.0 0.0
region hot prism 0 277.447 30 80 4 14 249.70 0.0 0.0
region cold prism 0 277.447 352 402 4 14 249.70 0.0 0.0
group hot region hot
group cold region cold
group hot_end region hot_end
group cold_end region cold_end
group end_one union hot_end cold_end
group fixed_heat_source_side region fixed_heat_source_side
group fixed_heat_sink_side region fixed_heat_sink_side
group end_two union fixed_heat_source_side fixed_heat_sink_side
group end union end_one end_two
compute Thot all temp/region hot
compute Tcold all temp/region cold
velocity all create $t 1198360
fix 1 all nvt temp $t $t 0.025
thermo 1000
run 200000
unfix 1
reset_timestep 0
fix 1 all nve
fix heatIN all ehex 1 2.30 region hot
fix heatOut all ehex 1 -2.30 region cold
velocity end set 0.0 0.0 0.0
fix set_end end setforce 0.0 0.0 0.0
I used prism style in region command for the triclinic system. Also, since I have a tilt in xy, I did not use INF for xlo, xhi, ylo and yhi. Rather I put specific values for them. After running the simulation, when the system equilibrates, the system temperature should be a constant value (in my case, I defined it to be around 300K). However, I cannot get the system to a constant tempeature, rather the temperature always increases exponentially till the last runsteps. Also, the source region should show higher temperature than the sink region but I am getting exactly opposite.
I am quite sure I am making some mistake in defining the region but I cannot seem to figure it out. Any help will be much appreciated.
