This is a copy of a question I got over email, thought I’d put it (and the answer) here so others could find it.
Hi Alex,
Thanks for integrating the previous fix so fast, and again for providing Rocketsled.
I wanted to also let you know about a couple changes I had to make to get it to run:
Run on my Windows sandbox, and, -
Run RS jobs that were not located in my Python install directory (I wanted to store my RS jobs in a separate work folder)
The changes I made were all in utils.py’s serialize() / deserialize() functions (see attached):
Change the “/” to Python’s “os.sep” OS-dependent filepath separator so it work son windows -
Modify serialize() to try getting the “wf_creator” function from the RS Job’s module first
Steps to reproduce:
Copy basic.py somewhere outside the Python installation dir
a. In this case, I used: C:\Users\abe\rmsit\workspaces\projects\ers3_rocketsled_scripts
Rename “basic.py” to “basic2.py” (or any other name that is not already used by a module in your Python installation dir) -
Run basic2.py
It errors out with:
File “”, line 1, in
runfile('C:/Users/abe/rmsit/workspaces/projects/ers3_rocketsled_scripts/basic2.py', wdir='C:/Users/abe/rmsit/workspaces/projects/ers3_rocketsled_scripts')
File “C:\ProgramData\Anaconda3\lib\site-packages\spyder_kernels\customize\spydercustomize.py”, line 786, in runfile
execfile(filename, namespace)
File “C:\ProgramData\Anaconda3\lib\site-packages\spyder_kernels\customize\spydercustomize.py”, line 110, in execfile
exec(compile(f.read(), filename, 'exec'), namespace)
File “C:/Users/abe/rmsit/workspaces/projects/ers3_rocketsled_scripts/basic2.py”, line 96, in
mc.configure(wf_creator=wf_creator, dimensions=x_dim)
File “C:\ProgramData\Anaconda3\lib\site-packages\rocketsled\control.py”, line 219, in configure
wf_creator = serialize(wf_creator)
File “C:\ProgramData\Anaconda3\lib\site-packages\rocketsled\utils.py”, line 122, in serialize
"you sure it's module is in your PYTHONPATH?".format(fun_path))
ImportError: Administrator.rmsit.workspaces.projects.ers3_rocketsled_scripts.basic2.wf_creator couldn’t be serialized to be imported. Are you sure it’s module is in your PYTHONPATH?
I added a print statement to print out the function path it was trying to resolve:
for _ in range(5):
try:
# if we couldn't find the func, try adding the parent folder name to the import path
full_import_path = all_pkgs[-1] + "." + full_import_path
all_pkgs = all_pkgs[:-1]
fun_path = full_import_path + "." + name
print("fun_path: {}".format(fun_path))
deserialize(fun_path)
return fun_path
except ImportError:
continue
else:
raise ImportError("{} couldn't be serialized to be imported. Are "
This is the output of the print statement:
2019-06-06 11:33:31,422 INFO Optimization collection opt_default hard reset.
fun_path: ers3_rocketsled_scripts.basic2.wf_creator
fun_path: projects.ers3_rocketsled_scripts.basic2.wf_creator
fun_path: workspaces.projects.ers3_rocketsled_scripts.basic2.wf_creator
fun_path: rmsit.workspaces.projects.ers3_rocketsled_scripts.basic2.wf_creator
fun_path: abe.rmsit.workspaces.projects.ers3_rocketsled_scripts.basic2.wf_creator
So it never tried to look up the base case “basic2.wf_creator”. I rearranged the code in the for-loop like so, but will defer to you on whether this is the right thing to do:
for _ in range(5):
try:
return fun_path
except ImportError:
continue
else:
The output of the print statement now gets “basic2.wf_creator” on the first iteration of the for-loop:
fun_path: basic2.wf_creator
I tested this out with Anaconda3 on a Windows 7 VM. Like I said, I will defer to you on whether these are the right code changes. I just know I had to make these changes to get it to work on my Win7 box, and I figured I’d share so hopefully it makes it easier for you. I would have done a pull request on Github, but I need to check on our corporate policies before I can do that, so I figured I would just email you to get it to you faster. Sorry about that.
If you have any feedback, please feel free to let me know!
Abe
