hi everybody,
we are about to implement some new functions into LAMMPS’ variable command that would allow to write input files that are:
- able to adapt automatically to different LAMMPS versions, i.e. where the syntax of individual commands change or when features are missing
- able to follow different strategies depending on which features are active, e.g. only use inner-middle-outer r-RESPA partitioning on the CPU, but not on the GPU.
- able to track whether particular fix/compute/region/group ids are defined
- able to query at run-time whether a particular style (fix/compute or pair/bond/…/kspace) is available in an individual executable.
point 1) has already been implemented, the variable command has now a “version” constant, that will output a numerical representation of the LAMMPS version string of the given executable. Here is a usage example from the manual. The following example, illustrates how this can work (since the version constant is new, it will - of course - fail with an error in old LAMMPS versions).
if $(version<20140513) then “communicate vel yes” else “comm_modify vel yes”
i am now looking for suggestions as to how the points 2)-4) are best integrated into the script language. is there anything that i am overlooking? is there something else, that should be integrated into this framework.
here is below is my current proposal for 2).
is_active(category,name,flag)
category = one of: package, comm_style, atom_style, units, newton, pair_style, bond_style, angle_style, dihedral_style, improper_style, kspace_style
name = the argument to the corresponding command that defines the category. in case of the ‘newton’ category either ‘pair’, ‘bond’, or ‘any’
flag = a keyword (or number?) to indicate whether an “exact” match is desired or, or the ‘name’ should be matched against the “lead”-ing part of the style, or any “substring” could be matched.
here is my proposal for 3)
is_available(category,name,flag)
same as before, but more categories including group, region, dump, fix, compute
and for 4)
is_defined(category,name)
category = one of: package, fix, group, compute, region, dump, variable
name = the ID/name of the object
here only exact matches would be allowed.
let me know what you think. i am happy to provide more explanations, if needed.
thanks,
