Request to add question to the forum (can not get high enough sp3 atoms while preparing amorphous carbon)
My research is related to the molecular dynamics simulation of amorphous carbon (a-C). Recently I had to prepare amorphous carbon containing different amount of sp2/sp3 atoms. So I tried the method described in this paper (http://ieeexplore.ieee.org/stamp/stamp.jsp?arnumber=7738454) where they followed the method of preparing a-C from their previous paper published in 2013 (https://doi.org/10.1016/j.apsusc.2013.09.073). I followed the same procedure using airebo potential, but unfortunately I could not get such high percentage of sp3 atoms in the prepared a-C. For instance, when I used density of 2.8g/cc (20A20A20A box, 1122 atoms), I got less than 20% sp3 atoms while the paper reported 64.58% sp3.
I have included my input file below. Would you kindly have a look and let me know what I did wrong?
Your help is highly appreciated. Thank you very much for your consideration.
My input file:
Lammps version: LAMMPS (9 Dec 2014)
atom_style charge
region box block 0 20 0 20 0 20 units box
create_box 1 box
create_atoms 1 random 1122 964723 box
mass 1 12.0107
group all region box
set type 1 charge 0
pair_style airebo 3 1 1
pair_coeff * * CH.airebo C
minimize 1.0e-8 1.0e-8 1000000 1000000
reset_timestep 0
timestep 0.00025
fix 1 all langevin 300 300 0.025 9536418
fix 2 all nve
thermo_style custom step temp press vol enthalpy ke pe etotal lx ly lz density atoms
thermo_modify lost warn
thermo 1000
run 20000
unfix 1
fix 1 all langevin 300 8000 0.025 7268134
run 40000
unfix 1
fix 1 all langevin 8000 8000 0.025 541397
run 8000
unfix 1
fix 1 all langevin 8000 300 0.025 9536418
run 8000
unfix 1
dump 2 all custom 10000 dlc_final.dump id type q x y z vx vy vz
compute 1 all coord/atom 1.75
dump 4 all custom 10000 coordination.dump c_1
run 20000
Sent with Mailtrack
paper (Investigation on the Graphitization Process of Amorphous Carbon for HAMR by Molecular Dynamics Simulation | IEEE Journals & Magazine | IEEE Xplore) where
published in 2013 (Redirecting). I
instance, when I used density of 2.8g/cc (20A*20A*20A box, 1122 atoms), I
please note that ​it is not the responsibility of this forum to review and
correct your work.​ people here have their own research to worry about.
if you have questions about the procedure in the paper you are referencing,
you need to either contact the authors of the paper, but beforehand i
strongly recommend, you discuss with your adviser/supervisor.
consideration.
My input file:
# Lammps version: LAMMPS (9 Dec 2014)
​please note that the AIREBO implementation in LAMMPS and LAMMPS in general
have seen multiple important bugfixes​ since 2014. it is strongly
recommended in case of problems, to test whether they persist with the
latest version of LAMMPS
