Dear Lammps Users
I have been trying to use rerun command to find the rdf of a polymer system. I think it is calculating the rdf, but not printing to the file while using fix ave/time command. I was not sure whether LAMMPS directly takes in the ix, “id” and “type” fields. When I tried to use field command of read dump, that was giving error too. I have not attached this extra part here
The script used to do so is attached. A small test version of the dump file used to read in the coordinates is also attached. Each time step has 19360 particles, but I have shown only a few lines. I have cross checked that the file contains the required timestep used for computing rdf. Also, coordinates were printed out every 100 timesteps (and I have tried to make Nevery Nfreq consistent with this)
Please find the attachments
Thanks in advance
Vaidyanathan M S
UT Austin
coord.1000000.txt (3.41 KB)
rerun.rdf (1.11 KB)
