I’m having a hard time extracting data via API, receiving a ‘MPRestError 504 time out’ message. Here is my code:
from pymatgen import MPRester
MAPI_KEY = "XXXXXXXXX"
m = MPRester(MAPI_KEY)
data = m.query(criteria={"e_above_hull":{"$exists":True}},properties=["pretty_formula", "e_above_hull"], chunk_size = 100, max_tries_per_chunk = 3)
This code, even without the ‘chunk_size’ has worked previously (extracting ~126,000 compounds), although now it sometimes only gets through a couple chunks before crashing, and sometimes none at all.
Does anyone know if there is anything I can do on my end to address this, or is it only due to too little RAM available for the request? And if so should I try the request at a time more off-hours?
Thank You!
