Axel,
Thanks very much!
You made a good point, I should have looked the stats more closely. Would converting the restart to text using the restart2data tool be instructive as to which commands translate from the original to the restart?
Thanks again,
Fred
Axel,
Thanks very much!
no. restart2data only looks at what is needed to generate a file for read_data.
what is carried over is listed in the documentation for each command.
And is documented in the read_restart command
doc page itself.
