Dear LAMMPS experts,
I have converted my restart file to data file through r2data command, I just want to know that whether a converted data file contains the assigned velocity of restart file or I have to reassign it?
Thanks in advance.
Thanks in advance.
You can check yourself so that you are 100% sure.
If there is the keyword “Velocities” in the converted data file then the velocities are contained.
An easy way is to check is to use grep command in Linux :
grep -i velocities name_data_file
Hope it helps
Evangelos Voyiatzis
Στις Σάββατο, 6 Ιουλίου 2019, ο χρήστης Hasnain <[email protected]…24…> έγραψε:
Thank you!
