I am using the version from 3 November, 2022 (built with the PYTHON module).
I want to obtain an array from Python, using the LAMMPS python
and variable
commands. It seems that the python
command wants you to hardcode how many characters an inline defined Python function returns. For example:
python fxn input 1 v_ntypz return v_fac format ii here """
def fxn(ntypz):
return 10
This works, because 10 has two digits, and format ii
specifies two digits. However, I`m wondering if there is a way to return an array. I’ve tried the following (as a VERY basic trial):
python fxn input 1 v_ntypz return v_fac format ss here """
def fxn(ntypz):
ap = []
for i in range(3):
ap.append(i)
return ap
variable fac python fxn
print "${fac}" #TEST CASE 1 (and comment out test case 2)
variable i loop 3 #TEST CASE 2 (and comment out test case 1)
print "${fac[i]}"
next i
I try here format ss
and format ii
(since list ‘ab’ being returned is a string-char string, but it is an array of integers… so decided to test with both). Now if I set format ss
here with TEST CASE 2, or if I format ii
here, for TEST CASE 2, I get the following error:
ERROR on proc 0: Substitution for illegal variable fac[i] (src/input.cpp:650)
Last command: ${fac[i]
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
[unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=1
system msg for write_line failure : Bad file descriptor
If I set format ss
here and try TEST CASE 1, I get
Segmentation fault (core dumped)
If I set format ii
-1
I’m (A) lost as to what is happening here (although something weird like “-1” for my ostensible list seems to be expected), and (B) in a pickle about how to proceed. My goal is to obtain an array using the python functionality of LAMMPS, and wondering the best way to proceed (and I want Python here, because I want to do some heavier manipulations).
I also noted the documentation suggests example suggests a format pf
combo (p - SELF, f - floating point), and I`m unsure what exactly one might do with that (I guess floating point makes sense, but the combo ‘pf’?).
edit: cleaned typos
