I am using OVITO’s python module, and would like to use the render_anim() function to animate the rotation of a single frame. How do I go about achieving that?
There is a OVITO GUI tutorial that handles your question.
There is also a corresponding Python example slightly hidden here in the TurntableAnimation(ModifierInterface) class.
These should give you a good starting point for your script.
Thanks for that!
This is how I’m doing it right now:
from ovito.modifiers import AffineTransformationModifier
total_frames = 12
def rotate_system(frame, data):
angle = 2 * np.pi * (frame / total_frames)
center = np.mean(data.particles.positions, axis=0)
cos_a = np.cos(angle)
sin_a = np.sin(angle)
R = np.array([
[cos_a, -sin_a, 0],
[sin_a, cos_a, 0],
[0, 0, 1]
offset = center - np.dot(R, center)
matrix = [
[cos_a, -sin_a, 0, offset[0]],
[sin_a, cos_a, 0, offset[1]],
[0, 0, 1, offset[2]]
data.apply(AffineTransformationModifier(transformation=matrix))
pipeline.modifiers.append(rotate_system)
pipeline.compute()
vp.render_anim(
size=(1500, 1500),
filename=f"abc.mp4",
background=(0,0,0),
renderer=TachyonRenderer(),
fps=1,
ffmpeg_executable='/usr/bin/ffmpeg',
ffmpeg_codec='libx265',
ffmpeg_quality='low',
range=(0, total_frames - 1)
I guess using it by defining it as a class and actually creating a trajectory/timeline of the frames is better?
Having it as a modifier class definitely helps OVITO handle caching of intermediate results and prefetching of data from disk, which can make pipeline evaluation faster and more efficient.
So I would say that when starting a new project, developing a modifier class is the better approach.
