Dear EMC,
I use trappe-ua force field for a simple acetamide molecule. When I examine the final results I see that the nitrogen is assigned a type “n3h2” , which is sp3 in amines with two connected H, but I was expecting the “n3mh2” - sp3 in amides with two connected H.
I also used the option “field_debug reduced” in *.esh file to see how the rules were applied to assign the atom types:
ITEM OPTIONS
replace true
mass true
density 0.5
number true
field trappe
field_debug reduced
build_dir .
pdb_compress falseITEM END
ITEM GROUPS
mol CC(N)=O
ITEM END
ITEM CLUSTERS
mol mol,2
ITEM END
and below is the relevant part associated with nitrogen type assignment:
mol:2 N(C(C)(=O))(H)(H)
core/field/apply/rules.c:202 [n3, no]
Debug: core/field/rule.c:425 112 n3 0 N(c)(c)(C(=O)(O))
Debug: core/field/rule.c:425 112 n3 0 N(c)(C(=O)(O))(C)
Debug: core/field/rule.c:425 112 n3 0 N(C(=O)(O))(C)(C)
Debug: core/field/rule.c:425 79 n3 0 N(C)(C)(C)
Debug: core/field/rule.c:425 104 n3mh2 0 N(C(=O))(H)(H)
Debug: core/field/rule.c:425 111 n3mh 0 N(c)(C(=O)(O))(H)
Debug: core/field/rule.c:425 111 n3mh 0 N(C(=O)(O))(C)(H)
Debug: core/field/rule.c:425 103 n3mh 0 N(C(=O))(C)(H)
Debug: core/field/rule.c:425 81 n3h2 0 N(C)(H)(H)
core/field/apply/rules.c:204 match ={id → 134, type → 59, reference → 81, element → “N”,
connect → {
{element → “C”, test → {flag → {bond → single}}},
{element → “H”, test → {flag → {bond → single}}},
{element → “H”, test → {flag → {bond → single}}}}}core/field/apply/rules.c:364 match = 0x1c71740
core/field/apply/rules.c:430 type[2] = n3h2…
The rule for “n3mh2” seems to fit perfectly to the chemical environment of a given nitrogen, i.e. N(C(=O))(H)(H), but for some reason it is ignored and continues until it reaches the rule for the amine nitrogen “n3h2”.
I would appreciate it so much if someone can suggest how to deal with this issue.
Thanks a lot in advance!
