Dear Dr. Montoya,
the log looks OK, the jobs starts, and craches after vasp starts and not finding the INCAR, POTCAR … the job directory after the crash contain only : atomate-2562062.error block_2018-08-10-15-08-49-829801 vasp.log
atomate-2562062.out FW_submit.script
while in rapidfire loaded from rocket, I can find all VASP files, POSCAR, INCAR …
python running :
from fireworks import Firework, FWorker, LaunchPad
from fireworks.queue.queue_launcher import rapidfire
from atomate.vasp.firetasks.run_calc import RunVaspCustodian, RunVaspFake, RunVaspDirect, RunNoVasp
from fireworks.utilities.fw_serializers import load_object_from_file
#from atomate.vasp.powerups import remove_custodian
queueadapter = load_object_from_file("/lustre/home/elbentr81/auto-dir/my_qadapter.yaml")
launchpad =LaunchPad(host=‘ds247061.mlab.com’, port=, name=‘tatitechno’, username= ‘tayeb’, password='*’)
if name == “main”:
rapidfire(launchpad, FWorker(), queueadapter , launch_dir='.', nlaunches=2, njobs_queue=4,
njobs_block=500, sleep_time=None, reserve=False, strm_lvl='INFO', timeout=None,
fill_mode=False)
I get:
/lustre/home/elbentr81/anaconda3/lib/python3.6/site-packages/pymatgen/init.py:35: UserWarning: With effect from pmg 5.0, all pymatgen settings are prefixed with a “PMG_”. E.g., “PMG_VASP_PSP_DIR” instead of “VASP_PSP_DIR”.
warnings.warn(‘With effect from pmg 5.0, all pymatgen settings are’
2018-08-10 20:15:07,039 INFO getting queue adapter
2018-08-10 20:15:07,039 INFO Found previous block, using /lustre/home/elbentr81/atomate/block_2018-08-10-15-07-03-101203
2018-08-10 20:15:08,232 INFO The number of jobs currently in the queue is: 0
2018-08-10 20:15:08,233 INFO 0 jobs in queue. Maximum allowed by user: 0
2018-08-10 20:15:09,349 INFO Launching a rocket!
2018-08-10 20:15:10,452 INFO Created new dir /lustre/home/elbentr81/atomate/block_2018-08-10-15-07-03-101203/launcher_2018-08-10-17-15-10-451541
2018-08-10 20:15:10,452 INFO moving to launch_dir /lustre/home/elbentr81/atomate/block_2018-08-10-15-07-03-101203/launcher_2018-08-10-17-15-10-451541
2018-08-10 20:15:10,454 INFO submitting queue script
2018-08-10 20:15:11,625 INFO Job submission was successful and job_id is 2562066
2018-08-10 20:15:11,626 INFO Sleeping for 5 seconds…zzz…
2018-08-10 20:15:17,736 INFO Launching a rocket!
2018-08-10 20:15:18,842 INFO Created new dir /lustre/home/elbentr81/atomate/block_2018-08-10-15-07-03-101203/launcher_2018-08-10-17-15-18-841873
2018-08-10 20:15:18,842 INFO moving to launch_dir /lustre/home/elbentr81/atomate/block_2018-08-10-15-07-03-101203/launcher_2018-08-10-17-15-18-841873
2018-08-10 20:15:18,845 INFO submitting queue script
2018-08-10 20:15:20,067 INFO Job submission was successful and job_id is 2562067
2018-08-10 20:15:20,068 INFO Launched allowed number of jobs: 2
atomate-2562062.out
<<FW_ auto Tayeb>>
2018-08-10 18:08:49,828 INFO getting queue adapter
2018-08-10 18:08:49,830 INFO Created new dir /lustre/home/elbentr81/atomate/block_2018-08-10-15-07-03-101203/launcher_2018-08-10-15-08-45-061561/block_2018-08-10-15-08-49-829801
2018-08-10 18:08:49,853 INFO The number of jobs currently in the queue is: 1
2018-08-10 18:08:49,854 INFO 1 jobs in queue. Maximum allowed by user: 4
OMP_NUM_THREADS= 1
Thank you very much for your Help !
Best regards.
Tayeb.
On Monday, August 6, 2018 at 9:04:20 PM UTC+3, Joseph Montoya wrote:
Hi Tayeb,
A few things:
- Your error message for lpad.reset makes me thing that there might be an issue with your mongo connection. Can you give us some more information? Have you confirmed that your database credentials are working for connecting to the mongo server on the supercomputer? Also, can you post the full traceback for your errors?
- I think that it’s likely possible to submit jobs from your own computer (i. e. via passwordless login), but this likely won’t work if there’s an issue connecting to the database as above.
- The vasp_cmd shouldn’t need to be set in the custodian code, it should be supplied as a parameter to the workflow constructor, or supplied as a env_chk parameter in both the constructor and the fireworker file.
Joey
On Aug 6, 2018, at 1:03 AM, [email protected] wrote:
Hi atomate group, Hi Joey,
I think I have restriction on running workflow on supercomputer, (lpad.reset is not working : operationFailure: there are no user authenticated , even-though the same notebook runs on my PC) so I am planning to prepare the workflow (notebook) on my PC, and submit it to the server. is this possible ?
my attempt so far is to created ssh connection so I can submit a job without password through command line : “ssh m…@server.adress sbatch /lustre/home/path/atomate.slurm”
but I don’t know how to configuration it in atomate, my attempt was to set vasp_cmd in custodian/vasp/jobs.py but it is designed for path, and atomate prints : FileNotFoundError: [Errno 2] No such file or directory:
Appreciate any help.
Thank you.
Tayeb. Ph.D
QEERI.
You received this message because you are subscribed to the Google Groups “atomate” group.
To unsubscribe from this group and stop receiving emails from it, send an email to [email protected].
To post to this group, send email to [email protected].
To view this discussion on the web visit https://groups.google.com/d/msgid/atomate/eed737ed-1729-46d3-8cf2-46350514b236%40googlegroups.com.
For more options, visit https://groups.google.com/d/optout.
