Hi all,
I want simulate a system(Brownian particles crossing a potential barrier) which runs backward in time. Is it possible use a negative value in time step or do i have to use a negative initial velocity?
Thank you,
Diljith T
Hi all,
Thank you,
Diljith T
Hi all,
to reverse a simulation you have to flip the sign of the velocity components. something like this (untested):
variable vx atom -vx
variable vy atom -vy
variable vz atom -vz
velocity set v_vx v_vy v_vz
please note that exact reversibility is only possible for NVE ensemble simulations (i.e. without thermostat or random forces) and fixed point math (LAMMPS uses floating point math).
Which is the way the LAMMPS logo on the webpage was animated.
Run N timesteps, flip the sign of the velocities, run N more steps.
Thanks.
In case you don’t already know, the links above and below the LAMMPS logo on the project home page (input script, physical analog and explanation) all seem to come up empty.
-David
I just fixed the link above the animation, pointing to the input script that generated the animation.
The 2 links below must have gone extinct at YouTube and Yale. I would insert
a joke here about YouTube outliving Yale, but apparently it was a close call.
