Hello.
I successfully compile GULP 6.2 using Intel compilers from Intel OneAPI (Intel(R) 64, Version 2024.2.1 Build 20240711).
The issue is running it, where I am getting the following error:
mpirun -np 2 gulp example1.gin
Abort(2139023) on node 0 (rank 0 in comm 0): Fatal error in PMPI_Init: Unknown error class, error stack:
MPIR_Init_thread(192)........:
MPID_Init(1665)..............:
MPIDI_OFI_mpi_init_hook(1625):
open_fabric(2726)............:
find_provider(2904)..........: OFI fi_getinfo() failed (ofi_init.c:2904:find_provider:No data available)
Running as gulp example1.gin, returns:
gulp example1.gin
[unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=2139023
system msg for write_line failure : Bad file descriptor
Program received signal SIGSEGV: Segmentation fault - invalid memory reference.
Backtrace for this error:
#0 0xbf5aca23c5d in ???
#1 0xbf5aca22d85 in ???
#2 0xbf5ac04531f in ???
at ./signal/../sysdeps/unix/sysv/linux/x86_64/libc_sigaction.c:0
#3 0xbf5a21e27f4 in MPIR_Err_return_comm
at ../../src/mpi/errhan/errutil.c:428
#4 0xbf5a230ea95 in PMPI_Init
at ../../src/mpi/init/init.c:160
#5 0xbf5ac4ffece in pmpi_init_
at ../../src/binding/fortran/mpif_h/initf.c:275
#6 0x557f0acb857b in ???
#7 0x557f0ad019c8 in ???
#8 0x557f09761a85 in ???
#9 0xbf5ac02a1c9 in __libc_start_call_main
at ../sysdeps/nptl/libc_start_call_main.h:58
#10 0xbf5ac02a28a in __libc_start_main_impl
at ../csu/libc-start.c:360
#11 0x557f09761ac4 in ???
#12 0xffffffffffffffff in ???
Segmentation fault (core dumped)
Any help is welcome!
Camps
