hi
After the installation of the MPICH software, it needs to be integrated into the system. For this you need to start a Command Prompt in Administrator Mode (right click on the icon and select it). Change into the MPICH2 installation directory, then into the subdirectory bin and execute smpd.exe -install.
I ran these commands but I got this error: can you help me to solve it?
You installed the wrong MPI library package. You need to download and install exactly the matching package linked from the website where you downloaded the LAMMPS installer package.
The precompiled LAMMPS windows executables will not work with the MS-MPI package, which is not compatible with the compilers used to build the installer packages.
If you want to use that MPI package, you also need to install the corresponding SDK and you need to compile LAMMPS from source on Windows yourself using the Microsoft Compilers included in the Visual Studio package (the community edition of Visual Studio is available at no cost).
This will not run in parallel, regardless of whether you have (the correct version of) MPI installed or not. It will not run at all, if you installed the MPI version of the LAMMPS package and not the correct MPI library package.
hi
For the MPI executable, after installing the mpich2-1.4.1p1-win-x86-64.msi and following the corresponding steps to run in parallel using this command " mpiexec -np 5 -locally lmp_mpi -in input1.txt"
i got this error:
Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\10688 registry key, error 5, Access is denied.
Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\7228 registry key, error 5, Access is denied.
Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\7096 registry key, error 5, Access is denied.
Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\9964 registry key, error 5, Access is denied.
Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\12804 registry key, error 5, Access is denied.
Setting up cg style minimization …
Unit style : metal
Current step : 0
Error posting readv, An existing connection was forcibly closed by the remote host.(10054)
unable to read the cmd header on the pmi context, Error = -1
WARNING: Ewald/disp Newton solver failed, using old method to estimate g_ewald (src/KSPACE/ewald_dipole_spin.cpp:161)
I have never seen the errors you are reporting, so I have no knowledge about how to resolve them. My speculation is that you may have done the extra installation steps to register the MPI service not from a command window with administrator privilege, but that is pure speculation.
Another possible explanation is that you did not reboot since registering.
Hello
Can you please tell me what the numbers in the following command are set for?
mpiexec -np 2 lmp_mpi -in in.lj -pk omp 2 -sf omp
I ran my input with the command “mpiexec -np 4 lammps-shell -in input.txt -pk omp 8 -sf omp”.
Then the performance is: 85.7% CPU use with 1 MPI task x 8 OpenMP threads.
Why 1 MPI task? I set it on 4
what is difference between “mpiexec -np 4 lammps-shell -in input.txt -pk omp 8 -sf omp”
and “mpiexec -np 4 lammps-shell -in input.txt” commands where both are using 8 OpenMP thread(s) per MPI task.
Please look it up in the LAMMPS manual. That is what a documentation is for.
Because the lammps-shell program is meant for interactive use, not with MPI. That is why it resets the number of threads used by default, too. This is all documented behavior. You are needlessly making your life miserable by ignoring it.
Hi, have you solved the error: Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\3828 registry key, error 5, Access is denied. I have encountered this problem, too.
I installed LAMMPS 64-bit 15Sep2022-MPI version and the mpich2-1.4.1p1-win-x86-64 and registered the mpiexec using the cmd window with an administrative privilege.
When I ran with mpiexec -localonly 16 lmp -in in.txt, I had the same error.
