Cheers, this successfully passes the partition flag!
I am now able to execute a NEB calculation from Fortran with equivalent results to the standalone program, but ran into an issue with the program crashing in segmentation fault after NEB finishes. I couldn’t find hints for debugging in the screen files, they all seem to indicate a successfully ended run.
Here is a minimal working example with the aforedescribed behavior. Commands to compile and run are the same as in your example, with the exception that I compile with mpifort instead of gfortran since I’m using the MPI library to call comm rank and size to interpolate the position of jumping atom.
program testlib
use mpi
use liblammps ! include the LAMMPS library interface
implicit none
type(lammps) :: lmp ! derived type to hold LAMMPS instance
character(len=12), parameter :: args(7) = &
[ character(len=12) :: 'liblammps', '-log', 'none', '-in', 'none', '-partition', '11x1' ]
character(len=512) :: cmds
integer :: i,myrank,nproc,error
integer,dimension(18) :: types=1,ids=[(i,i=1,18)]
!# 3x3x2 fcc {100} slab with nearest neighbour distance equal to 1.0
double precision,dimension(3*18) :: x=[0.0,0.0,0.0,&
1.0,0.0,0.0,&
2.0,0.0,0.0,&
0.0,1.0,0.0,&
1.0,1.0,0.0,&
2.0,1.0,0.0,&
0.0,2.0,0.0,&
1.0,2.0,0.0,&
2.0,2.0,0.0,&
0.5,0.5,sqrt(0.5),&
1.5,0.5,sqrt(0.5),&
2.5,0.5,sqrt(0.5),&
0.5,1.5,sqrt(0.5),&
1.5,1.5,sqrt(0.5),&
2.5,1.5,sqrt(0.5),&
0.5,2.5,sqrt(0.5),&
1.5,2.5,sqrt(0.5),&
2.5,2.5,sqrt(0.5)]
!# Initial and final coordinate of a jumping adatom
double precision,dimension(3) :: xinit=[0.0,0.0,sqrt(2.0)],xfinal=[0.0,1.0,sqrt(2.0)],xjump
! create a LAMMPS instance (and initialize MPI)
lmp = lammps(args)
cmds="units metal"//new_line("a")//&
"atom_modify map array sort 0 0.0"//new_line("a")//&
"region box block 0 3 0 3 0 5"//new_line("a")//&
"create_box 1 box"//new_line("a")//&
"pair_style lj/cut 2.5"//new_line("a")//&
"pair_coeff * * 1 0.890899"//new_line("a")//& !# Lennard-Jonesium with nn distance 0.890899*2^(1/6)=1.0
"mass 1 1"
call lmp%commands_string(cmds)
!# Add slab atoms
call lmp%create_atoms(id=ids,type=types,x=x)
!# Freeze the bottom layer
call lmp%command("group frozen id 1:9")
call lmp%command("fix freeze frozen setforce 0.0 0.0 0.0")
!# Add jumping atom; interpolation based on processor rank
!# to pass replica coordinates without file I/O
call mpi_comm_rank(MPI_COMM_WORLD,myrank,error)
call mpi_comm_size(MPI_COMM_WORLD,nproc,error)
xjump=xinit+myrank*(xfinal-xinit)/(nproc-1)
call lmp%create_atoms(id=[19],type=[1],x=xjump)
cmds="fix neb_fix all neb 1.0"//new_line("a")//&
"min_style quickmin"//new_line("a")//&
"min_modify dmax 0.01"//new_line("a")//&
"neb 1e-3 1e-4 1000 1000 100 none"
!# Attempt to see if each replica can report its own energy to
!# get the barrier without file I/O; crashes before this line
print *,myrank,lmp%get_thermo("pe")
!# delete LAMMPS instance (and shutdown MPI)
call lmp%close(.true.)
end program testlib
