Dear Nomad developers,
I would really appreciate some simple howto or documentation about how to run Oasis in a Kubernetes cluster. The docs claim this is possible, but there is no documentation as far as I can see. While I have at this point some experience with the docker or bare-linux approaches, Kubernetes is completely new to me, so I would appreciate any help I can get.
Internally, we use a NOMAD helm chart to run NOMAD on our k8s cluster. You can use this chart. However, the chart does not include mongodb or elasticsearch at the moment. So those would need to be manually added by you. The values.yaml
associated with the chart, roughly follows the nomad.yaml
config keys.
This might be a good starting point for you. Unfortunately, the whole thing is not documented or build for independent use at the moment. We want to have this at some point, but we are in the middle of too many things right now to spontaneously do it now.
Thanks a lot @mscheidgen,
I think this should get me started, hopefully out IT guys can help me a bit with the details. I’ll get back with more questions if I get stuck at some point.
Small question regarding the helm chart, I don’t need anything for the keycloak section as long as I have
oasis:
is_oasis: true
uses_central_user_management: true
right?
Yes, you should not need anything. There is only the client_secret
, which is only necessary for the central NOMAD. With uses_central_user_management
your Oasis will get all user information from the central NOMAD and not form keycloak directly.
