runstruct_vasp hangs with Debian 7 replacing Debian 6
Since "The distribution [on the NIST CTCMS cluster] was upgraded from Debian 6.0 to Debian 7.0," runstruct_vasp does not work. Instead it hangs for as long as one waits. :frowning:
To debug this, I’d need you to try this:
csh -v "runstruct_vasp [your options]"
so I can see where it hangs.
I tried:
20 (alfred) 291 >csh -v ~/bin/runstruct_vasp
and got:
set wrapfile="vasp.wrap"
while ( $#argv != 0 )
if ( ! $?extractonly ) then
if ( ! -e ~/.ezvasp.rc ) then
source ~/.ezvasp.rc
set VASPCMD="vasp"
set POTGGA="/usr/local/lib/pot_gga"
set POTLDA="/usr/local/lib/pot_lda"
endif
if ( ! $?notgenvaspin ) then
str2ezvasp $wrapfile
Where it seems to hang again
Ben
Also:
20 (alfred) 292 >ps
PID TTY TIME CMD
2401 pts/15 00:00:00 tcsh
9045 pts/15 00:00:00 csh
9049 pts/15 00:00:00 str2ezvasp
9059 pts/15 00:02:56 cellcvrt
9060 pts/15 00:01:51 tail
9274 pts/15 00:00:00 ps
28932 pts/15 00:09:21 maps
2
Apparently cellcvrt is generating an infinite loop:
13 (ruth) 169 >cellcvrt -c < POSCAR
1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
-nan -nan -nan
-nan -nan -nan
-nan -nan -nan
end
-nan -nan -nan
-nan -nan -nan
-nan -nan -nan
end
-nan -nan -nan
-nan -nan -nan
-nan -nan -nan
end
0.595446 0.744462 0.803922
0.368373 0.750989 0.413670
0.441689 0.918591 0.570800
0.671725 0.918791 0.967204
end
0.726071 0.769667 0.730027
0.914388 0.958669 0.919188
0.000000 0.000000 0.000000
end
end
end
-nan -nan -nan
-nan -nan -nan
-nan -nan -nan
end
and more of the same
OK, problem solved.
It seems that when I installed a new version of atat,
cellcvrt did not update in my bin directory, and after
updating by hand runstruct_vasp seems to work perfectly.
SOrry for the inconvenience.
Ben
ok good! I was scratching my head on this one!
