Dear lammps users,
I have the exactly same data file and input file, which is a 10000 atoms polymer structure. I ran the script both on my desktop and on a cluster.
My desk top use AMD quad-cure cpu and have 4GB memory. On the cluster I use 1 node with two hex-core cpu with 12GB memory. but the simulation result is totally different.
I know there will be some differences if we ran simulation on different computers, but those results are totally different.
also, I don’t think my desktop have any problem, because I ran a 20000 atoms polymer simulation on it and it gives the same(or say similar) result as I run on that cluster.
Could someone please give some explanations? How to solve such problem or something I should be beware of?
Thank you all
Yueqi
Please clarify what constitutes a totally different result.
Axel.
Are you using same version of LAMMPS?
Oh, thanks for point this out. I do used a different version of lammps.
On my desktop, I use the LAMMPS windows parallel executable – C++ version (1 July 2012)
On the cluster, they build the LAMMPS 31Aug11 with the linux redhat version.
I will try to run the script on my desktop under the Ubuntu system again and see how it goes.
but that is not the reason. the reason for the fast divergence between
the two trajectories lies in the use of the langevin thermostat. this
contains a random component obtained from a pseudo random number
generator and that *cannot* be consistent when you run with a
different number of MPI processes, even if you use the same random
seed.
in any case, there is no indication that the trajectories give a
"different result". the actual individual coordinates of the total
system and kinetic energy are hugely irrelevant in MD simulations.
what matters are the averages over the ensemble and - provided you are
in equilibrium - over time. this seems to be given here and thus the
simulations are *not* giving a different result. i suggest to read up
on this in a text book on MD simulations, as this is one of the
fundamental concepts here and must be understood to be able to use MD
successfully.
