I know I can do "dump_modify simulation element Fe Cr He" and then get:
128000
Atoms. Timestep: 200
Fe 0.0160486 114.643 114.619
Cr 1.43427 1.39655 1.44747
Fe 2.86522 114.582 114.653
Cr 4.29715 1.39228 1.42944
Fe 5.70815 114.58 114.647
But for the purposes of other programs, it would be better to have the atomic numbers, instead of the atomic symbols. Is that possible without external tools or shell commands? (I don’t want to modify atom types, since that breaks the LAMMPS simulation.)
Hi again,
I don’t know what I’m missing here (maybe because it’s a custom dump and not xyz?):
atom_style atomic
atom_modify map yes
lattice bcc 2.8664999
region R1 block 0 1 0 1 0 1
create_box 1 R1
create_atoms 1 box
group Region1 region R1
fix integrate all nve
fix reset all dt/reset 10 1e-05 0.001 0.028664999 units box
pair_style eam/alloy
pair_coeff * * fe_mendelev_eam_alloy.potential Fe
dump simulation all custom 1 simulation.xyz id type x y z
dump_modify simulation element 26
run 0
Dumps:
ITEM: TIMESTEP
0
ITEM: NUMBER OF ATOMS
2
ITEM: BOX BOUNDS pp pp pp
0.0000000000000000e+00 2.8664999000000000e+00
ITEM: ATOMS id type x y z
1 1 0 0 0
2 1 1.43325 1.43325 1.43325
The type is not being replaced by the atomic number.
Why should it? What LAMMPS does is completely logical and following the documentation.
Your dump_modify command modifies the “element” property, not “type” itself (which you cannot). In dump style xyz the type value is used as fallback, if no elements have been set.
