Hello!
I am running into a problem with trying to save MPDocs in a format that can be accessed as an MPDoc when opened offline.
I have seen this discussion before but none of the methods that were mentioned have successfully worked for me.
Here is my code to gather all available MPDocs (with my api key):
mpr = MPRester(api_key)
docs = mpr.materials.summary.search()
I successfully gather the docs and try to dump them by:
from monty.serialization import dumpfn, loadfn
from emmet.core.utils import jsanitize
sanitized_docs = jsanitize(docs)
dumpfn(sanitized_docs, "mp_docs.json.gz")
This command goes through, but when I try to load the file I get the error:
loaded_docs = loadfn("mp_docs.json.gz")
File /Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/json/init.py:293, in load(fp, cls, object_hook, parse_float, parse_int, parse_constant, object_pairs_hook, **kw)
274 def load(fp, *, cls=None, object_hook=None, parse_float=None,
275 parse_int=None, parse_constant=None, object_pairs_hook=None, **kw):
276 “”“Deserializefp(a.read()-supporting file-like object containing
277 a JSON document) to a Python object.
278
291 kwarg; otherwiseJSONDecoderis used.
292 “””
→ 293 return loads(fp.read(),
294 cls=cls, object_hook=object_hook,
295 parse_float=parse_float, parse_int=parse_int,
296 parse_constant=parse_constant, object_pairs_hook=object_pairs_hook, **kw)
563 hex(self._crc)))
564 elif isize != (self._stream_size & 0xffffffff):
565 raise BadGzipFile(“Incorrect length of data produced”)BadGzipFile: CRC check failed 0xa0452f91 != 0x3e6a3d16
Any ideas on how to save the MPDocs locally to be able to retrieve them as MPDocs offline? Thanks!
