Hi
In the Langevin thermostat the seed which decides background noise, it takes one value for a run.How can one use it(seed) as variable so that during a loop run ,one gets different paths for the system after minimisation.
Thankyou
Andri
please do not add my e-mail address when sending mails to the
lammps-users mailing list. there is no benefit to it, since i am
already subscribed and gmail will notice, that both e-mails are the
same and thus will deliver only one of them. but it creates extra work
(and thus irritation) for me, since this circumvents the filtering to
put mailing list e-mail into its own inbox, forcing me to sort such
e-mails manually.
Hi
please have a look at the variable command and the two different ways
how variables are being used. please also note, that there is a
"random()" function (and check out how it works), that can be used in
variables. the rest should be systematic and logical thinking, which
is something you should practice as well, because sooner or later,
you'll have to learn to solve such simple problems for yourself.
people answering questions here are usually quite busy...
