Dear sir,
I’m a user of lammps software. I find that there is a little difference in the example files(elastic and elastic_T). There have energy minimization instruction by min_style cg in the example of elastic, but there haven’t energy minimization instruction in the example of elastic_T. I wonder if it is necessary to add the energy minimization instruction to elastic_T and where it should be added , especially when some atoms are added or deleted in geometric modeling. I wish I can get your help. Thanks for you help.
Dear sir,
I'm a user of lammps software. I find that there is a little difference in the example files(elastic and elastic_T). There have energy minimization instruction by min_style cg in the example of elastic, but there haven't energy minimization instruction in the example of elastic_T.
minimization will bring back your system to 0K. that is hardly
desirable when trying to determine the elastic constants at finite
temperature.
as reasoned above, adding minimizations would be counterproductive.
however, it should also be understood, that you should start from a
properly equilibrated geometry. including the equilibration into this
procedure would be a massive waste of CPU time, as it would have to be
needlessly repeated.
