I have met a problem about Segmentation fault.
I don’t know if it’s because of the lack of RAM on the Linux system, or if it’s because the ffield is not the right one
I’m grateful for your help ![]()
Following are some details :
input files
# 3D LAMMPS simulation of oxygen and hydrogen combustion
units real
neighbor 2.0 bin
# Set atom style and read data files
atom_style full
read_data 6.data
# Set potential
pair_style reaxff NULL
pair_coeff * * CHOFeAlNiCuSCrXNCl.ff C H O Fe N
fix 8 all qeq/reax 1 0.0 10.0 1e-6 reaxff
region mobile block INF INF INF INF 13 87 units box
group mobile region mobile
group C type 1
group H type 2
group O type 3
group N type 4
region boundary block INF INF INF INF 0 13 units box
group boundary region boundary
group Fe_boundary type 5
group O_boundary intersect boundary O
group O_boundary type 6
velocity boundary set 0.0 0.0 0.0
fix 5 Fe_boundary setforce 0.0 0.0 0.0
fix 6 O_boundary setforce 0.0 0.0 0.0
min_style cg
minimize 1.0e-4 1.0e-6 100 1000
reset_timestep 0
fix 9 all nvt temp 1500.0 1500.0 100
fix 10 all reax/c/species 1 1 100 species.out element C H O Fe N
fix 11 all reaxff/bonds 1000 bonds.reaxff
# Set up simulation
timestep 0.1
thermo 1000
thermo_style custom step temp press pe ke etotal cpu time
thermo_modify flush yes
dump 1 all custom 1000 dump.lammpstrj id mol type q x y z
restart 500000 restart.equil
run 5000000
error message
srun: ROUTE: split_hostlist: hl=b01r3n[0203-0204] tree_width 0
LAMMPS (3 Aug 2022)
OMP_NUM_THREADS environment is not set. Defaulting to 1 thread. (src/comm.cpp:98)
Reading data file ...
orthogonal box = (0 0 0) to (33.7759 33.7759 112.7503)
2 by 3 by 8 MPI processor grid
reading atoms ...
1252 atoms
special bond factors lj: 0 0 0
special bond factors coul: 0 0 0
0 = max # of 1-2 neighbors
0 = max # of 1-3 neighbors
0 = max # of 1-4 neighbors
1 = max # of special neighbors
special bonds CPU = 0.011 seconds
read_data CPU = 0.085 seconds
WARNING: Changed valency_val to valency_boc for X (src/REAXFF/reaxff_ffield.cpp:296)
576 atoms in group mobile
80 atoms in group C
360 atoms in group H
484 atoms in group O
288 atoms in group N
672 atoms in group boundary
40 atoms in group Fe_boundary
384 atoms in group O_boundary
CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE
Your simulation uses code contributions which should be cited:
- pair reaxff command:
- fix qeq/reaxff command:
The log file lists these citations in BibTeX format.
Neighbor list info ...
update every 1 steps, delay 0 steps, check yes
master list distance cutoff = 12
ghost atom cutoff = 12
binsize = 6, bins = 6 6 19
2 neighbor lists, perpetual/occasional/extra = 2 0 0
(1) pair reaxff, perpetual
attributes: half, newton off, ghost
pair build: half/bin/newtoff/ghost
stencil: full/ghost/bin/3d
bin: standard
(2) fix qeq/reax, perpetual, copy from (1)
pair build: copy
stencil: none
bin: none
Setting up cg style minimization ...
Unit style : real
Current step : 0
Per MPI rank memory allocation (min/avg/max) = 11.67 | 18.07 | 23.56 Mbytes
Step Temp E_pair E_mol TotEng Press
0 0 -124476.98 0 -124476.98 1567.452
13 0 -128062.43 0 -128062.43 -4093.4537
Loop time of 0.974932 on 48 procs for 13 steps with 1252 atoms
98.5% CPU use with 48 MPI tasks x 1 OpenMP threads
Minimization stats:
Stopping criterion = energy tolerance
Energy initial, next-to-last, final =
-124476.980803798 -128057.742224055 -128062.430651954
Force two-norm initial, final = 2431.7458 362.80936
Force max component initial, final = 264.74512 89.090493
Final line search alpha, max atom move = 0.0017649401 0.15723938
Iterations, force evaluations = 13 26
MPI task timing breakdown:
Section | min time | avg time | max time |%varavg| %total
Pair | 0.011336 | 0.1172 | 0.47499 | 36.4 | 12.02
Bond | 1.9922e-05 | 2.6383e-05 | 3.866e-05 | 0.0 | 0.00
Neigh | 0 | 0 | 0 | 0.0 | 0.00
Comm | 0.0028405 | 0.062982 | 0.16893 | 22.2 | 6.46
Output | 0 | 0 | 0 | 0.0 | 0.00
Modify | 0.41541 | 0.41968 | 0.42008 | 0.1 | 43.05
Other | | 0.375 | | | 38.47
Nlocal: 26.0833 ave 124 max 0 min
Histogram: 24 8 5 4 1 0 0 0 4 2
Nghost: 537.146 ave 947 max 126 min
Histogram: 6 2 10 2 10 0 0 6 2 10
Neighs: 3691.46 ave 25325 max 0 min
Histogram: 37 5 0 0 0 0 0 0 4 2
Total # of neighbors = 177190
Ave neighs/atom = 141.52556
Ave special neighs/atom = 0
Neighbor list builds = 0
Dangerous builds = 0
Setting up Verlet run ...
Unit style : real
Current step : 0
Time step : 0.1
Per MPI rank memory allocation (min/avg/max) = 23.54 | 30.79 | 36.44 Mbytes
72000 1486.503 -3404.3489 -124513.62 5543.16 -118970.46 1496.1602 7200
73000 1485.241 -4173.5483 -124675.55 5538.4537 -119137.1 1516.427 7300
74000 1506.7218 -3471.485 -124643.93 5618.5558 -119025.37 1537.69 7400
75000 1480.0038 -3514.2526 -124364.7 5518.9243 -118845.78 1558.8846 7500
76000 1551.5321 -3857.8025 -124440.07 5785.653 -118654.42 1579.7286 7600
77000 1502.3437 -3884.5452 -124329.25 5602.2296 -118727.02 1600.5859 7700
78000 1472.3741 -4372.4408 -124384.48 5490.4731 -118894.01 1622.7955 7800
79000 1436.3456 -3704.0996 -124189.29 5356.1232 -118833.16 1644.811 7900
80000 1505.563 -3419.6018 -124377.02 5614.2344 -118762.78 1666.3343 8000
81000 1533.7328 -3532.3972 -124342.17 5719.2796 -118622.89 1688.3002 8100
82000 1489.3653 -3821.754 -124287.71 5553.8333 -118733.88 1709.5499 8200
[b01r3n0203:14848:0:14848] Caught signal 11 (Segmentation fault: address not mapped to object at address 0xc2cfb87c)
==== backtrace (tid: 14848) ====
0 0x000000000004d455 ucs_debug_print_backtrace() ???:0
1 0x00000000011c090b _INTERNALbecf47cc::ReaxFF::Validate_Lists() /work/home/jsyadmin/L4/wys/LAMMPS/shangcheng/intel/lammps-3Aug2022_install_intel/source/src/REAXFF/reaxff_forces.cpp:112
2 0x00000000011c090b _INTERNALbecf47cc::ReaxFF::Validate_Lists() /work/home/jsyadmin/L4/wys/LAMMPS/shangcheng/intel/lammps-3Aug2022_install_intel/source/src/REAXFF/reaxff_forces.cpp:112
3 0x00000000011c0681 ReaxFF::Compute_Forces() /work/home/jsyadmin/L4/wys/LAMMPS/shangcheng/intel/lammps-3Aug2022_install_intel/source/src/REAXFF/reaxff_forces.cpp:374
4 0x00000000011c0681 ReaxFF::Compute_Forces() /work/home/jsyadmin/L4/wys/LAMMPS/shangcheng/intel/lammps-3Aug2022_install_intel/source/src/REAXFF/reaxff_forces.cpp:377
5 0x00000000011ad87a LAMMPS_NS::PairReaxFF::compute() /work/home/jsyadmin/L4/wys/LAMMPS/shangcheng/intel/lammps-3Aug2022_install_intel/source/src/REAXFF/pair_reaxff.cpp:482
6 0x00000000009ff3f2 LAMMPS_NS::Verlet::run() /work/home/jsyadmin/L4/wys/LAMMPS/shangcheng/intel/lammps-3Aug2022_install_intel/source/src/verlet.cpp:316
7 0x000000000098deec LAMMPS_NS::Run::command() /work/home/jsyadmin/L4/wys/LAMMPS/shangcheng/intel/lammps-3Aug2022_install_intel/source/src/run.cpp:176
8 0x0000000000791748 LAMMPS_NS::Input::execute_command() /work/home/jsyadmin/L4/wys/LAMMPS/shangcheng/intel/lammps-3Aug2022_install_intel/source/src/input.cpp:845
9 0x000000000078eb0b LAMMPS_NS::Input::file() /work/home/jsyadmin/L4/wys/LAMMPS/shangcheng/intel/lammps-3Aug2022_install_intel/source/src/input.cpp:301
10 0x000000000040416f main() /work/home/jsyadmin/L4/wys/LAMMPS/shangcheng/intel/lammps-3Aug2022_install_intel/source/src/main.cpp:98
11 0x00000000000223d5 __libc_start_main() ???:0
12 0x0000000000404029 _start() ???:0
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= RANK 0 PID 14842 RUNNING AT b01r3n0203
= KILLED BY SIGNAL: 9 (Killed)
Thank you in advance. ![]()
