Dear LAMMPS Community,
I hope this message finds you well. I am currently encountering an issue with LAMMPS when attempting to run simulations in parallel using 6 processors (mpirun -np 6). I’m experiencing a Segmentation Fault error at signal [11], but interestingly, the program runs without error when I use 4 processors (mpirun -np 4).
I have performed some initial troubleshooting, such as checking for memory issues, ensuring proper compilation, and reviewing my input scripts and data files, but I have not been able to identify the root cause of this issue.
I am currently using 23Jun2022 version.
I have also attempted to debug the issue using gdb, but I haven’t been able to pinpoint the exact location of the error.
If anyone in the LAMMPS community has encountered a similar problem or has insights into debugging Segmentation Fault errors in a parallel LAMMPS simulation, I would greatly appreciate your guidance and expertise.
Additionally, if you require any additional information or logs to help diagnose the issue, please let me know, and I will provide them promptly.
Thank you in advance for your assistance, and I look forward to your valuable input.
