I am trying to get a Phonon dispersion curve via an output ‘bin’ file and ‘in.disp’ file attached below, by using “phana ‘full name of bin file’ > in.disp2” command as suggested in readme.txt. However, I am getting an error with “Segmentation fault (core dumped)”. I have installed phana as per the instruction of Dr. Kong on the official website after installing tricubic and clapack packages. Kindly help me with the same.
NOTE: I am not attaching bin file, since it is 4.2 GB in size. Kindly let me know if anyone requires the same. I will send it via google drive.
Thanking you,
Deep
in.disp2 (19 Bytes)
