Dear LAMMPS users,
I have a problem related to segmentation fault.
LAMMPS version I used is 11Apr15 and I ran the simulation with multi-processors.
All of my input script are read by LAMMPS well.
The log file shows “Setting up run …”.
Afterwards, however, error occurs and simulation stops. “5 total processes killed (some possibly by mpirun during cleanup)”
I tested to find which line or command is problematic.
when i include a command below
compute bcpmol bcp chunk/atom molecule &
nchunk once limit 0 ids once compress no
segmentation errors shown below occur.
Without that command, simulation is continued.
*** Process received signal ***
Signal: Segmentation fault (11)
Signal code: Address not mapped (1)
Failing at address: 0x210
[ 0] /lib64/libpthread.so.0 [0x338220e4c0]
[ 1] /phome01/p425jsh/lammps-11Apr15/bin/lmp_cheetah(_ZN9LAMMPS_NS16ComputeChunkAtom14compute_ichunkEv+0x4ec) [0x57942c]
[ 2] /phome01/p425jsh/lammps-11Apr15/bin/lmp_cheetah(_ZN9LAMMPS_NS6Modify5setupEi+0x9f) [0x88f3bf]
[ 3] /phome01/p425jsh/lammps-11Apr15/bin/lmp_cheetah(_ZN9LAMMPS_NS5Respa5setupEv+0x655) [0xc58e25]
[ 4] /phome01/p425jsh/lammps-11Apr15/bin/lmp_cheetah(_ZN9LAMMPS_NS3Run7commandEiPPc+0xd3f) [0xc5bd4f]
[ 5] /phome01/p425jsh/lammps-11Apr15/bin/lmp_cheetah(_ZN9LAMMPS_NS5Input15command_creatorINS_3RunEEEvPNS_6LAMMPSEiPPc+0x29) [0x85e3d9]
[ 6] /phome01/p425jsh/lammps-11Apr15/bin/lmp_cheetah(_ZN9LAMMPS_NS5Input15execute_commandEv+0x23e5) [0x858835]
[ 7] /phome01/p425jsh/lammps-11Apr15/bin/lmp_cheetah(_ZN9LAMMPS_NS5Input4fileEv+0x1fb) [0x85483b]
[ 8] /phome01/p425jsh/lammps-11Apr15/bin/lmp_cheetah(main+0x94) [0x871e04]
[ 9] /lib64/libc.so.6(__libc_start_main+0xf4) [0x338161d974]
[10] /phome01/p425jsh/lammps-11Apr15/bin/lmp_cheetah(_ZNSt8ios_base4InitD1Ev+0x41) [0x4d8d09]
*** End of error message ***
Thank you very much.
Sehun Joo
